Question about Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television
Vertical bars running across tv and horizontal haziness that fluctuates
  • 438 Answers
Are these bars slowly moving slowly like a snake kinda thing ? let me know
Posted on Jan 31, 2010
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Intermittent black or snowy horizontal bar across the top
You're somewhat sound in electronics I assumes. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help.
May 17, 2013 | JVC PD-42WV74 42 in. Plasma EDTV
At first it briefly had the vertical bars running across then stopped and now It smells and has an message ee
Hello
The horizontal output section of your standard tV should be troubleshooted. There is smot shorted component/s. You have to open your tV to check it. Check the horizontal output transistor, which dirves the LOT. If found shorted, replace it along with LOT.
Let me try to insert the images of these components here. The first two images, have wires are LOTs. You have to check which type is fitted to your set, and have to buy an exact type, both in number and size. The images horizontal output transisotrs is also attached here.
Feb 21, 2012 | Televison & Video
Green hazy upside down arch of color across the screen
Your convergence board is in need of reworking on a component level or replacing the board! And you will most undoubtedly need to resolder the vertical IC and all ICs mounted on heatsinks on the power supply board. This TV is showing its age. You may choose to repair and that may last a year more or so! Good Luck and thank you for asking!
Jun 20, 2010 | Mitsubishi VS-50605 50" Rear Projection...
I have an horizontal bar across the center of this TV.
Sounds like you have a bad vertical i.c(common problem in that model) and capacitors along with it that needs to be replaced. not much you can do at home to fix it, you`ll need help from a tv repairman. good luck
Nov 02, 2009 | Samsung TXH2879 28" TV
Permanent horizontal line approx. 4" from top of screen
if this line is in the picture, that is possible burn in screen. if you have a black bar at the top or faint white lines that come down from top this is caused by defective filters in vertical circuit or bad vertical output. mch
Feb 20, 2009 | LG 50PC3D 50 in. Plasma Television
Hoizontal Bar across RCA Model 24F501TDV Color TV
you may need to change your resolution on tv settings as well as cable or satelite settings if you have one of those
Dec 12, 2008 | RCA 24F501TDV 24" TV
Cant get a picture
check the vertical section dry solder or vertical ic supply or is vertical ic is short. please let me know the ic number for clear idea
Jun 24, 2008 | Hitachi 35UX85B 35" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Camera taking very hazy pictures
First thing to try is to reset all your settings to default. It is possible to manually set the shutter time so that it stays open for a long period of time. If that is not the problem it is also possible that your shutter is not functioning properly. Do you see any vertical or horizontal lines running across your picture? (these would be totally straight not wavy like the movement from your exposure). If you do see that it is possible that your shutter is not closing at all when you take a picture. David Millier Advance Camera Repair
Feb 13, 2007 | Nikon Coolpix 5400 Digital Camera
Toshiba TheaterWide 52HM84 52" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
