Question about Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402
Only have about 15 min of hot water and the water is not as hot as it use to be
  • 617 Answers
Water heaters will fill up with sediment,because of this they have a less than 10 year lifespan.As they fill with sediment you have less room for water and it's harder to heat up.Try and flush the heater by opening the over flow valve for a couple of minutes.Open the drain at the bottom too.
One thing,as with any build up,once cleaned you can develop a leak.The reason being that there had always been a leak it was only plugged up,and by cleaning you will sometimes find a leak that never was there before.That means the tank integrity is gone and will need replacement.
Nuff said?
Posted on Jan 31, 2010
Reduced Hot Water
Water heater 14 years old, probably has never been flushed, Flush recommended at least every 6 months, Build up inside tank may be to late to flush, but you can try or replace heater.
press the helpful button
Feb 11, 2016 | Element Water Heaters
Low pressure coming from Hot Water Tap
Were is the water boiler located.
Feb 20, 2014 | Water Heaters
Hot Water Pressure from taps
Hard water deposits from the water heater in the supply lines to the faucets. Sounds like your water heater needs to be cleaned out -- not just drained of water. You need to get inside and clear out the deposits in the bottom of the tank. You also need to remove the hot water supply lines to your faucets and see of you can get the lines to run free from the deposits -AFTER you clean out the water heater. Remove the drain -put on a 3/4 in. ball valve for the drain and a hose bibb on that - you can hook up a 5/8 - or 3/4 inch hose to get the particles out of the drain of the water tank. You may have to blow back the water line, from the faucets, the hot water lines- to get the deposits out of the water lines. You also may have to blow out the faucets with the water line disconnected to clear the calcium out of the hot side of the faucet.
Feb 18, 2014 | Water Heaters
1 shower appx 15 mins long and now very little hot water after 3 hrs
With out make and model help is very limited, it appears it is an electric heater. You probably have a bad heater. More then likely it has two heaters. It is Oslo possible the thermostat is bad.
Feb 06, 2014 | Water Heaters
Bosch gwh 425 hn
Fix problem immediately same day, yourself, for $385, by replacing whole thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Bosch posts some service manuals: or contact Bosch. Lack of error code indicates failed PC board? or bad single-handle faucet cartridge?
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
Check for crossover where bad faucet cartridge allows cold water to enter hot pipe, so hot water is not drawn through tankless and burner does not activate... but this might not be problem since you hear the tankless clicking
http://waterheatertimer.org/Crossover.html
Call local service technician to catch up on required yearly maintenance.
Jun 09, 2013 | Water Heaters
Atwood 10 gallon H2O heater- replaced thermal couple and electrode spark and sensor but heater comes on with switch, heats water for 10 to 15 mins then burner goes out. Can hear a couple of switching...
I'd check that ECO and thermostat discs are making contact properly with tank.Just peel back foam cover on outside of tank that has ECO and THERM marked on it. If they are installed correctly, replace them.
Aug 06, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water is cutting out after 2 - 3 minutes whilst showering
check the screen on the cold water intake on the cold side,, you might have to flush the system out, and do you have the shower head water restricter in, if not you may be using to much hot water,,, how many other hot water fixtures are running at the same time? try running just the shower,,,if this is a tank water heater the dip tube could be bad that is on the cold side it takes the cold water to the bottom of the tank and forces the hot water out,, if you ar only getting a couple of min of hot water and the dip tube is bad it is not going to the bottom but just at the top and not getting all the hot water you will need a plumber
Mar 21, 2009 | Water Heaters
No hot water out of a rtg-74pvp-1 tankless water heater
in order to reset the unit you will have to turn the temp all the way down then unplug the unit for 5 min,, remember it is a computer and it knows, after plugging in back in after the five min, reset the temp open up a fauset while doing this, that way it will be regestering the flow of water to set the temp by
Dec 18, 2008 | Rheem Tankless Hot Water Heater...
Rheem 40 GAL ELEC TALL Water Heater 6YR SC 82VH402 Logo
95 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
