Question about Maytag Washing Machines
Iam haveing a error code of f51 on my maytag washer was woundering what it meant
  • 311 Answers
There are two possible causes of this code an unbalanced load can cause this error, The unit usually tries a few times to redistribute the load before it will display this error. Try another load if the error occurs then you have bigger problems. The other cause could be a bad rotary position sensor on the motor in which case you would probably want to call a tech.
Hope this helps _MJ_
Posted on Jan 31, 2010
F51 maytag bravo error code?
The F 51 code, would indicate, the control board is not seeing the proper resistance on the motor circuit .
You should check and make sure there are not any articles, stuck between the tubs, or under the agitator.
Make sure you're not overloading the machine.and you have proper voltage to the unit.
Have you run the unit through a cycle empty ?
You may want to try that, before we have to get too involved in circuit and voltage tests.
Your technical data sheet should be on the inside of the front panel, you'll need to raise the top of the washer, using a putty knife to release the clips in the front seam, holding the top down .
Maytag washer Error Code F51 Appliance Repair Forum
Apr 06, 2015 | Maytag Washing Machines
Washer wont spin. F51 code
the f51 error indicates that your rotor position sensor) is not registering or it is just bad. try this, remove and reinstall the connector at the RPS at least three times to clean off any corrosion built up on the connector and RPS due to the intermittent connections. after that go ahead and try to run a cycle. if you continue to receive the error then you need to replace the RPS sensor. Here is that part to order. Whirlpool W10178988 Sensor AppliancePartsPros com
Oct 05, 2014 | Maytag Bravos MTW6600T Top Load Washer
What does it mean f 51
http://forum.appliancepartspros.com/washer-repair/131926-maytag-washer-error-code-f51.html
Jan 30, 2013 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer flashes f 51
You will need to replace the RPS sensor. There is a kit available that will update that washer to the current design. Here is the kit to order.
Nov 23, 2012 | Washing Machines
Washer does not work it goes into error code f51
F 51 error code means the computer cannot detect that the motor is turning properly. The most common cause of this problem is an article of clothing has gotten between the basket and tub and is stopping the basket from turning freely. There are several other possibilities but I have seen this cause an F 51 error code many times. Hope that helps.
Aug 29, 2011 | Maytag Washing Machines
I have a Maytag Bravos washing machine that has just recently become really noisy when it goes into high speed spin. I have lifted the cover and found no items or debris. When I spin the tub by hand it...
Hi.
F51 is motor position sensor error. From manual:
F51: Motor RPS Failure
F then 51 flashes when there is a motor rotor position sensor (RPS) failure or lower harness problem.
The motor position sensor failure may be the result of a problem between basket and motor.The parts below the basket must be inspected. There is need to remove the basket to check parts in there. I can give you the procedure to remove the basket if you want.
Aug 20, 2011 | Maytag Bravos MTW6600T Top Load Washer
My Maytag 300 quite series has a code F51 what does this mean?
Hi and welcome to FixYa, I am Kelly The F51 code is a motor rotor position sensor (RPS) feedback error. In other words the control board is not sensing any motor rotation. It is fixable but will result in the replacement of failed parts. (Sensor or electronic control board) The control board is not cheap. Hopefully you only have a failed sensor.
Thanks for choosing FixYa,
Kelly
Feb 16, 2011 | Maytag Bravos MVWB400V Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
271 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
