Question about Tappan TGF657 Gas Kitchen Range
Tappan oven is heating up way past where the temperature is set. I even set it to 200 degrees. It goes up back 375 and still kicks in the heat up!
  • 221 Answers
Sounds like a defective thermostat, look inside the oven for a sensor. It should hang from the oven top or high up on either side attached to a little clip. Looks like a metal thermometer.  If it is missing or damaged that would explain the problem and must be replaced.
Posted on Jan 31, 2010
Oven Pre-heats too high
Your oven sensor has gone bad and telling the control board/thermostat to keep heating. Find the model number on the range and go to a parts distributor like repairclinic.com or apdepot.com and order you sensor. This is an easy repair.
Apr 23, 2012 | Dacor ER36D Dual Fuel Range
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
Ovens won't heat up beyond 250 degrees.
if you cant program it for more than the 270 you may have changed it from farienhiet ( bad spelling) to celcius. pushing and holding broil may switch it back.
May 02, 2009 | KitchenAid Architect ® II KEBS208S...
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Gas Furnace doesn't come back on after giving heat for a while.
This is an erratic operation of the thermostat you can reset the thermostat. Please check the reset operation procedure of the installation manual
Nov 18, 2008 | Tappan 30IN ELEC IGNa Oven
Whirlpool Accubake - Can't get out of clean mode
cannot get out of clean mode, although the oven outside is cool, but door is locked and display still says cleaning, door locked and time of 3 hrs 15 min is displayed. NOW WHAT?
Nov 16, 2008 | Kitchen Ranges
Possible Control board problem
You may not necessarily need a new control panel. Sometimes the oven temperature can be calibrated. Look in your owner's manual (if you have one) for calibration instructions. This will usually take care of the problem. If not, you may have to replace the oven sensor located inside the oven in the upper right or left hand corner of the back wall. Good luck.
Feb 06, 2008 | Kitchen Ranges
Oven not working
Per this page (http://www.repairclinic.com/0078.asp#Tappan), it sounds like you need to replace your oven temperature sensor.
Feb 23, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan TGF657 Gas Kitchen Range Logo
205 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Mike Carew
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
