Question about GE Washing Machines
I had asked what to do if the agitator doesnt move on the spin cycle BUT what i needed to say was the drum doesnt spin. the water does drain though
  • deedeez Jan 31, 2010
    ge washer model # wksr2100taww and serial # dt187700g
  • 129 Answers
MODEL AND SEIAL #
Posted on Jan 31, 2010
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Hoover optima 614 drum wont spin
Either a broken drive belt or a failed transmission.
Jan 12, 2015 | Hoover Washing Machines
Washer wont spin or drain
Yes, you can check the LID switch as it needs to activate the program to move forward. If the water fills up and there is no wash cycle, check if the motor hums, if so check the capacitor, check the friction on the spindle/drum. If the spindle does not agitate with movement the assembly must be reset.
Jan 23, 2013 | Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
May 20, 2009 | Maytag PAV2300 Top Load Washer
Just out of storage, my washer is having difficulties.
Hi, There are capacitors that give an initial boost to start the motor moving and these tend to go bad from sitting for long periods, that's why you could give it an assist and it would work, you are providing the extra boost. Helping it though causes other problems, like belt and voltage control problems, so that is not a good idea. You should have it looked at if you are not electrically or mechanically inclined. Best of luck to you!
Feb 13, 2009 | GE WBSR3140DW Top Load Washer
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire Washer won't drain
Sounds like a bolt on the agitator shaft is broken which is causing the imbalance. Open lid, lift off fabric softener dispenser, pull out plastic cap, take out bolt, lift agitator out(might have to wiggle it a bit). Replace BOTH horizontal bolts holding inner tub to shaft. Tighten all the way. Replace all parts.
If it doesnt spin all the water out, that could be due to a bad bearing. Hold inner tud at the rim and turn clockwise and then anti-clockwise. If it turns bothways, you have a worn bearing. This job isnt for the do-it-yourselfer.
What is happening is the motor is spinning the bearing but it's not engaged to the drum.
Jun 22, 2008 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
