Question about LG LRSC-26922 Side by Side Refrigerator
The ice-maker is water inlet is frozen how do i remove it, or unblock it?
  • 1,531 Answers
The best way to get rid of the water is use a blow dryer heat the tube and fill valve it make take some time but it works remember not to keep the heat in one area to long.
Posted on Jan 31, 2010
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
The Icemaker in my whirlptool side by side model ED5HVAXVL02 is not producing ice. The LED light just blinks Red. It blinks 2times then pause for 1 second. I have read that it means that the optics are...
2 blinks and a pause means your optics are good . Most of the time the ice maker is bad and needs replaced . Put about 2/3 cup of water in the ice maker and if it dumps , replace the water inlet valve AND check the black fill tube which fills the ice maker to see if it is frozen . If so , this is also an indication of a seeping ( leaking not closing completely ) water valve .
Jul 02, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Frigidaire Model # GLRS267dzw2 ice maker isn't filling up with water too make ice.
As every technician knows , a water and ice dispensor refrig , has a dual water inlet valve . Just because the water dispensor works , does not mean the coil for the ice maker is working . Pour about 2/3 cup of water into the ice maker . If it dumps the frozen cubes , but does not refil with water , check the fill tube inside the freezer , from the wall to the fill cup on the ice maker , to see if it is frozen . If so , replace the dual water inlet valve , due to seeping . This is not closing completely , and letting drips thru , which freeze inside the tube . If the tube is not frozen , then the water inlet valve is bad , not letting water thru to the ice maker .
If the ice maker does not dump the frozen cubes , then the ice maker needs to be replaced . Also check the coils under the refrig , to be sure they are clean of dust , lint , etc , as this will raise the temp above 5 degrees , which is the operating temp , for an icemaker .
Oct 11, 2009 | Refrigerators
The ice maker on my refrigerator has stopped making ice. Water is still flowing but the tray doesn't fill and the whole mechanism seems not to function.
Pour about 2/3 cup of water into the ice maker . If the ice maker dumps the frozen cubes , but doesn't refill with water , you should replace the water inlet valve , behind the refrig , where the wall water line connects to . If the Ice maker does not eject the frozen cubes , replace the ice maker .
Also , check the ice maker fill tube , from the back wall inside the freezer , to the ice maker fill cup , to see if it's frozen . If so , you will need to remove it , and clean the ice out . This would be caused by a " seeping " bad water valve also .
Check the coils under the refrig , to make sure they are clean of dust , lint , pet hair , etc , as this will raise the freezer temp above 5 degrees , which is the temperature which the ice maker needs to operate properly .
Oct 10, 2009 | Refrigerators
I just replaced my icemaker on a kenmore fridge #2537481240g I heard the soleniod(water valve) enage and the ice maker has gone thru 3-4 cycles but still no water? any suggestions?
Fill tube above ice maker may be frozen. Remove the fill line from the back of the unit where it comes out of the solenoid valve, force ice maker into a harvest put hose in a bucket and see if you get any water when it actuates the valve, the valve may have a clogged screen or not opening at all. If you get water, then you have a frozen fill tube
Jun 13, 2009 | Refrigerators
ICE MAKER
Sounds like you are not getting enough water into the ice maker tray. When the ice ejector removes the ice from the tray, it may be causing the ice to splinter which is the crushing you describe. The problems could be:
* The water inlet valve
* The ice maker water inlet is partially frozen in the freezer section
* There is a problem with the water line (kinked or partially obstructed)
* The timing mechanism for the inlet water valve isn't working correctly
Check #2 from the above list first
Mar 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice maker not working -
If the inlet in the freezer is frozen then the water valve is leaking. Replace the water valve.
Feb 13, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice maker not making ice
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker not making ice, model KSR125F
one of fours things can be wrong,first make sure it's on,second remove the supply tube in the freezer and look to see if it is frozen, thaw with hair dryer,third the water inlet valve has failed,fourth the icemaker itself is bad,put your hand in the ice maker well to see if you feel water if you do the water inlet valve is working and the icemaker itself has failed if you don't feel any water the water inlet valve has failed,let me know,thanks-mike
Jun 23, 2008 | Refrigerators
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
LG LRSC-26922 Side by Side Refrigerator Logo
286 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
