Question about Goldstar MA-1011 Microwave Oven
Its not taking power - Goldstar MA-1011 Microwave Oven
  • Goldstar Master
  • 9,047 Answers
Was it elected?
Posted on Jan 31, 2010
My plmv169dcd stopped working,looks like it has no power, but there is power at plug in. is there a reset button>
Not quite enough information. But, there is no reset button. Open unit check fuse. test all 3 door switches. They are the number one cause of problems and can take out the fuse or not. Other than that it will take more trouble shooting to find the problem
Dec 03, 2014 | Electrolux Frigidaire Professional Series...
Tip
Home alone for home electronics
I have come across many complaints of home systems not working when one comes back after a long holiday. This made me think to give some tips so as to take care of your dear products while you are away.
To start with disconnect cable line and power to your TV and Home System , Disconnect power generally to all the other appliances if the period of absence is more than a month.
Now the most important part is that in many cases moisture build up, condensation and insect infestation can be the biggest problem apart from power related issue for which we take off the cable and take power plug off.
Cover the concerned appliance with a GOOD BLANKET to keep it warm within. If there are devices with battery you can remove battery or keep them connected to power specially cordless phones. But laptops can be kept off power. Micro waves must be clearly covered as the kitchen appliances are most vulnerable to such problems.
when you return after the holiday the clocks might have to be set after switch on .
However many may dispute to say that the power can be put on but in many cases lack of human interference results in insects to barge in and cause havoc. Hence if you in such a threat and environment, try this out.
Also you may end up saving power by switching off the fridge during this long period.
Hope this tip finds use with a purpose.
on Aug 19, 2010 | Microwave Ovens
How do i adjust power level
There are no heat levels on a microwave oven, only power levels. I am not aware of any method of checking the power level except to boil water. Boil water at each level and time how long it takes to boil. The lower the power, the longer it should take. If there are no differences in the time, the oven is not functioning as expexted.
Sep 13, 2014 | Haier Microwave Ovens
Will not power on - newly installed
If the plug is providing power to the microwave oven it means the main fuse is open, I would suggest taking it back because once you take it apart it will void your warranty.
Mar 02, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
Takes about 35 mins to get water to start to boil
Check your power setting. If it has been set lower, it will take longer to cook. Normally, the max power setting is used unless a recipe calls for a lower setting. Normally, the setting is at 10.
Best regards, --W/D--
Feb 05, 2011 | Microwave Ovens
How do I take apart my dyson dc04 to fit a new wire
Ensure the device is disconnected from any power source before taking any of it apart. The power button is held in by a little catch which can be accessed by a small hole between the button and the vacuum body. Even if you can find something that fits down the hole it will be difficult to clear the latch. Once the button is out there is a torx screw holding the actual switch and wires down. The wires all have spade fittings inside plastic sheathes. Ensure the device is disconnected from any power source before taking any of it apart.
Sep 15, 2010 | Microwave Ovens
Microwave powers up but it doesn't heat
If you see the turntable on and the lights on it does not mean that the microwave main component the magnetron is not powered.
You will need to open the set after switching off the power and see if the relay clicks to power the magnetron. if so the main capacitor to this unit is short or failed.
If all these are checking ok , then the magnetron itself could be faulty.
Please take care when you check these circuits as high voltage and microwave is present. Please take care to shield yourself.
Hope my advice helps . Good day
Aug 18, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The tray is not turning anymore
you can take the bottom panel off from underneath. the motor is there. you can take a volt meter and check if the motor is getting power. if it is not getting power the control board is messed up- which is costly to fix
Apr 14, 2009 | Microwave Ovens
No power ge spacemaker microwave
You might need to take the back panel off of the microwave and replace the fuse. Make sure you get the same amp as the one you take out.
Apr 04, 2009 | GE Microwave Ovens
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Goldstar MA-1011 Microwave Oven Logo
51 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
