Question about Kenmore Elite 45986 Front Load Washer
The washer won't drain. I've had the problem
The washer won't drain. I've had the problem before and the repairman just cleans out the drain. Can I do that myself so that I don't have to give up a day of work to wait for a repairman?
  • 438 Answers
Yes you certainly can, but the best way to learn is to have the repair person come over and watch what they do to clean it, and ask questions
Posted on Jan 31, 2010
Hoover elite 700 washing machine won't spin
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
# A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
# 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
# 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
# 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
# 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
Regards.
Jan 05, 2012 | Hoover Washing Machines
Will not spin after wash
INSTRUCTION BELOW
Jan 04, 2012 | Washing Machines
Lg wm2455h is not draining: i have taken out and cleaned pump filter and that did not correct the problem. I place the machine on the drain and spin cycle and i can hear the pump hum, but doesnt drain. ...
most likely you have a bad pump and it needs to be changed out or something is still stuck in the impellar,stick your finger into the pump and feel around the impellar,i've found under bra metal pieces stuck in there,elastics and string rapped around it and coins lodged in between the impellar and wall of the pump,if the pump is bad or something is stopping the impellar from spinning it will hum,power is going to the pump but the motor isn't spinning.
Nov 12, 2011 | Washing Machines
Water remains in the dishwasher
Hello.
There are several reasons that a washing machine,or dishwasher won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
1 A dishwasher won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
3 Loose or broken belts could also prevent a dishwasher from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4 Another possibility for a dishwasher to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5 If all of the above steps fail to produce a dishwasher that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thanks.
Oct 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Won't spin out water but pump works
1.A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
2.If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.3.Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
4.Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
5.If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Thank you for using FixYa and please don't forget to rate me.
thanks,
Reymond
Oct 18, 2011 | Maytag Washing Machines
My washer will not drain, It completely stops when it hits the spin cycle.
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
Regards.
Apr 29, 2011 | Washing Machines
Drain error still after making sure the washer was level, making sure the drain filter was clean, the drain was clear and replacing the pump motor assembly
LE error? Don't buy a new sensor, don't call a repairman and don't scrap it. The fix is EASY!
Turn the drum 4-5 times by hand to resettle the load, move spin speed to highest, Quick Wash, Speed Wash. It shoudl work just fine. I've had to do this a few times over the last 5 years. Why everyone wants you to BUY parts is beyond me....maybe they need to make some $$ ?
Apr 21, 2011 | LG WM-2277HW Front Load Washer
Dishwasher will not drain
I hope the above helps;
Good luck.
Apr 13, 2011 | Dishwashers
My washer don't spin or drain the water
welcome to Fixya.
Good luck.
Apr 08, 2011 | Whirlpool Washing Machines
Bosch washer wont drain
you do not need a repairman! Buy the correct part from appliancepartspros.com-they are very helpful (I checked the part number on the BOSCH website first). The aprt cost me $48 and some cents. I (being a professional woman, = not a repairwoman!) changed the unit in less than 45 minutes. See my other posts for the procedure.
Jun 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
120 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
