Question about Bionaire BT45RC Tower Fan
We have an older Bionaire (maybe 6 years old; not tall and slim like the picture shown and no round base) that has been working perfectly. It still heats up OK, but is making a beeping sound that continues even though the unit is off. I have to unplug it for the beeping to stop. Any clue what's going on? I've lost track of the remote...
  • dmstraiko Jan 31, 2010
    How do I "check and replace" the auto shutoff?
  • 542 Answers
This indicates the autocutt off function is not working properly. Need to check and replace will resolve your problem.
Revert back for more assistance.
Posted on Jan 31, 2010
  • Rajesh Pai
    Rajesh Pai Jan 31, 2010
    You cannot replace the same by your self. Need to replace the same with the help of expert engineers or service center experts.
Bionaire BCH9212 does not produce heat
These Bionaires (including your 9212 and its taller version, the 9224) have a small temperature safety relay mounted slightly above the ceramic heating elements. Its purpose it to shut off the elements if they overheat, which I would assume would happen if the fan stops working or possibly if the outlet to the front becomes blocked (and these ceramic elements, which are like a radiator core, do get a lot of dust accumulated on the inside which will block air flow). The sensor is a small unit with exposed contacts and if these contacts open (driven by the temperature sensor connected to them) or if these contacts do not have good contact (say by dirt or oxidation build up that makes them effectively fully or partially open) then the ceramic elements will not work. My best suggestion to explain your problem is that the contacts on that safety switch became dirty during storage. The only way to verify that (and possibly repair the unit) requires taking the outside shell off and cleaning the contacts of the safety switch with either a small, fine file (like the old ignition files) or maybe fine emery cloth.
Nov 30, 2011 | Bionaire Heating & Cooling
I have an older 12 year old 37" Toshiba tv. When I
A capacitor in the vertical circuit is taking time to build up a charge, and allow the vertical circuit to function properly. If you can get a schematic, you might be able to find it and change it out. It will be an electrolytic capacitor, shaped like a round barrel, and they are inexpensive, but you have to disassemble the whole unit to get them changed out.
I would live with it, unless you're very adept at electronics.
I could work for years like this, until it finally gives out.
Good luck, and hope this helps.
May 25, 2011 | Toshiba 27A42 27" TV
Heater won't stay on, I heard there was a recall on this item.
Hi and welcome to FixYa, I am Kelly.
I am only answering part of your question (Recall) so do not rate the post so other experts can help you with your heater won't stay on problem.
Your heater model is not one of the 4 models that were recalled.
The recall involves Holmes® models HFH6498-U, HFH6500-U and HFH6500TG-U and Bionaire® model BFH3530-U. The recalled heaters also have date codes beginning with 2604 through 3804 for all units, except for Holmes® model 6500TG-U, which has date codes ranging from 2604 through 4704. The model and date code can be found on the silver label on the back of the unit. The heater fans are 26 inches tall; come in all gray, two-tone gray, or black and gray; and have either the word Holmes® or Bionaire® printed on the front of the base.
See this link for more details:
http://www.holmesheaterrecall.com/
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
I haven't used it in one year and now it won't turn on. (Bionaire BT46R)
The motor may just be stiff, or seized. take the cover off, and try spinning it with your hand. then plug it in and try it. if it doesn't work, then it's probably done. I just fixed mine today, but the base on mine was just loose. but it shouldn't be too hard to take apart.
Aug 13, 2010 | Bionaire BT46R Tower Fan
How can i change the filter in my bionaire model bcm 7207
on that model that you have you need to turn the unit off , take the water tank off, then the base where the fan is should come off. under the main base the filter will be under that. all you do is take the old filter off and put the new filter on. if you have any other questions please let us know.
Feb 26, 2010 | Bionaire BCM7207-U Humidifier
Replace humidifier filter
turn the unit off then take the tank off then the base which is the fan portion and the filter fits right there.. if it's a round filter then it slips right on. now if it's the squares they will slip into some slots and usually they will take about 4 if that's the case. if you have any other question please feel free to let me know.
Jan 09, 2009 | Bionaire BCM7207-U Humidifier
New ps2 game won't play on older ps2 game console. Help!?
You're stuck not being able to play, you need to get the slim PS2's because they reconverted the discs for a new disc encoding.
Dec 25, 2008 | Sony PlayStation 2 (PS2) Console
Bionaire BT45RC Tower Fan Logo
93 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
