Question about Koss C928 System
Disk stuck in Koss c928. DVD powers up and says waiting. How do I get the disk out and how do I reset unit
  • 110 Answers
There should be a small hole on the door of the disk tray. insert a paper clip in the hole to manually open the disk tray. remove the disk and see if the tray will open and close normally. If it does put another disk in and see if all is well. If not I would have a repair center look at it.
Posted on Jan 31, 2010
My dvd player koss ks2503 stopped working ,i changed the fuse but it still not working
Check the capacitors in the power supply and replace the ones that are large and/or leaking. They usually look puffed up on the top. Also check the solder connections on the power supply. Very common with these "KOSS" units.
Jul 18, 2011 | Koss KD250 DVD Player
The dvd player is frozen, and a dvd is stuck inside . how can I get my dvd back?
I have one that is the same way, but looks like the circuits never reset, all lights stay on. plus will not open
Nov 15, 2010 | Aiwa XD-DV370 DVD Player
Surround sound speakers won't work
I have the same problem. This works for some people, it didnt work for me. 1. Remove any discs 2. turn the unit off and unplug 3. wait about 20 secs and replug the power cord. 4. turn unit back on .Press dvd button on the remote to take unit to the dvd mode. 5.Using remote enter 76419. The display should say GOODBYE and go off. Press the power botton again to turn on and good luck
May 24, 2009 | Koss KS3102 System
Curtis DVD player - Stuck in Load Mode so won't open - dvd inside - correctly seated - but may not be compatible. I just burned it & was testing it.) Have tried the paper clip in the tray release...
Do the following
Unplug power cord.
Wait two minutes and plug it back.
Keep repeatedly pressing the eject button while you start the unit, before it starts reading cd inside. Do this a couple of times.
If you cannot eject the disk in this way you will need to take unit apart.
Unit won't start until the disk is inside, as it tries to read the disk , disk is faulty and unit get stuck.
Aug 26, 2008 | Televison & Video
Surround on my system
Have you tried what I said and changed the settings in the DVD?
Also, is it a built in DVD player / TV combo, or a separate unit? You can try doing a hard reset..Unplug the TV from the mains, disconnect all cables from tv and wait for 1 hour. Then press the power button on TV and plug in the mains. Same if your DVD player is stand alone.
Try that and let me know..
May 10, 2008 | Koss KS3102 System
KOSS HOME THEATRE
Salutations robn7499,
There are a few things that may cause this to happen. First I would check your connections for your center channel speaker. in movies with 5.1 surround sound almost all the vocal tracks come out of the center channel.
Otherwise there maybe an issue with the volume levels for the center channel as well, these can normally be adjusted through the setup of your home theater system.
I hope this helps.
Jon
Go Ahead. Use Us.
May 06, 2008 | Koss C928 System
Koss dvd player
Perhaps the sled motor is stuck on the unit. What model number is it? Can you remove the screws on the cover and try to open it manually moving the sled mechanism? (carefully of course, with very little force). It might just need to be lubricated.
Dec 02, 2007 | Koss KD260 DVD Player
Koss C220 System
Try to load up a basic CD audio disc and see it works?If it doesn't,you need to repair your unit or buy a GOOD brand new like panasonic,samsung or Denon.
Nov 16, 2007 | Koss KS2503 System
Sound but no video
Run your yellow cable from the DVD player directly to the TV in the port connected to the red/white cables. If this is already done or doesnt, work, let me know
Jul 26, 2007 | Koss C928 System
Koss C928 System Logo
148 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
