Question about Magic Chef CGR3725 Gas Kitchen Range
My gas range oven is not working and showing p3 sign
  • Magic Chef Master
  • 3,253 Answers
HI ITS a short or defctive oven sensor
Posted on Feb 08, 2010
My oven stopped working, broiler works also burners
I'd suggest testing to see if the burners are getting lit. If not, it might mean the ignitor has failed. To check the burner, select Bake to turn on the oven and then open the oven door. After a few seconds you should see an orange glow through the bottom of the oven and hear the hissing of the gas. If you don't, then the burners probably didn't light and I would suspect the ignitor. If it is the ignitor, this posting shows how I fixed my oven with the same problem:
http://www.fixya.com/support/t130970-ge_xl44_gas_oven
Apr 16, 2015 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas oven won't light. Stovetop works fine.
I have the same problem with my whirlpool gas oven. The top burners work fine, but when we turn the oven on, the ON sign on the display stays on for about a few seconds and then goes away. The oven doesn't light up. Please help
Aug 23, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
About six months ago, my GE XL44 gas range (purchased Dec 2002) started showing signs that it's not maintaining the oven temp I set. I tried running the self-clean cycle, but that didn't change anything....
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My whirlpool oven electronic pad flashing f3eo
The error code E0 F3 indicates that the oven temperature sensor in your range is open. This error code can also mean that the electronic oven control in your range has failed. Disconnect the electricity to your range for 2-3 minutes. This will reset your control if it is just confused.
If the error code persists someone needs to access the back of the electronic oven control and read the resistance of the oven temperature sensor. The sensor is connected to terminals P3-5 and P3-6 on the electronic oven control by two violet wires. The sensor should read around 1100 ohms at 70 degrees
If the sensor reads more than 100 ohms more or less than 1100 it is defective. If the sensor reads within 100 ohms of 1100, the electronic oven control has failed and will need to be replaced.
Dec 18, 2008 | Kitchen Ranges
Lost power, now oven won't work and display shows "FFF"
I didn't catch the first line in my first response "Lost power, now oven won't work and display shows..." I am 99.999% sure when the power company restored your power they hit you with a surge that wiped out the low voltage transformer on your ERC (main oven control board). Call your power company and report it. I doubt they will cover the cost to repair but they should! Can't hurt to ask and have them file a claim
Dec 18, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
Maytag Gemini bottom oven not working
both ovens on my new stainless steel maytagmgr6775 not heating up.............
Dec 08, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Rangemaster 110
i used the solution above worked great as i never used the clock anway . but instead of removing the whole hob i simply un screwed the front panel 5 scews. pulled the front panel out about an inch and used a pair of long nose pliers to remove the blue wires cliped them together. then just screwed the panel back took about 5 mins.
Nov 01, 2008 | Rangemaster 110 (Gas) Kitchen Range
Maytag gas
Peace,
ngafm here at your service,
There maybe a gas valve problem that must be tested to diagnose!
Bless you,
ngafm
Please give me a good rating in at this site before you sign off!
Thank You
Jun 05, 2008 | Maytag MGR5751AD Gas Kitchen Range
My frigidaire gas range oven won't work
Hello Welcome,
If you get a F1 this means Circuit board is defective.
And you need to Check or replace: the control board.
This is a job for service to be sure before you buy the control board!
Thank You Huuum.
Please remember to leave a solved rating before you sign off!
May 21, 2008 | Frigidaire FGF337 Dual Fuel (Electric and...
Baking oven
if you got no display form clock assy ck the power lines leading to that control, unplug and relpug unit might have just glitched out, no clock no bake on this model all oven function run throughthis clock/control
Feb 28, 2008 | Tappan TGF363 Gas Kitchen Range
Magic Chef CGR3725 Gas Kitchen Range Logo
44 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
