Back to:
Tags:
New World E70DOa Electric Double Oven
Too hot
posted by Baggyns on Feb 18, 2008
I have moved my New World E70DOa into a built-in housing and it is melting the acrylic doors that it is next to. Shouls there be a metaln plate/shield that goes around the oven to prevent this?
Thanks,
George.
Comment by Baggyns, posted on Feb 18, 2008
It's front vented, and hot air comes out at the top as I guess it's supposed to. Bu the oven door gets very hot at both sides as well as on top of the top plate.
George.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
Not Rated (0)
anonymous111
Rank:Wiz Wiz
Rating: 92%, 41 votes
first thing is to check if it is front vented or rear vented, if it is front vented you will find warm air blowing out above the door. if not it is rear vented and must have a flu installed behind unit.
Comment by anonymous111, posted on Feb 19, 2008
with out seeing it, it sounds like the door hinges either may not be in place properly or they may need replacing. does the door shut firmly at the top or is there a little slack? and what are the cooking temps like, is food burning?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on too hot:
I don't want to Accept this solution
Can you Help with these Ovens problems?
Ovens
My wife recently cleaned the oven and when she started...
Ovens
my oven turns of after 25 minutes and wont come back on...
i have a newworld DFEO 70 Electric Cooker the grill switch...
set the clock and timer
some how i have changed the timer noise to the low...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
