Question about Iomega ZIP 100 MB SCSI (10011) External ZIP Drive
What are the power requirements for this model? I don't have the original power transformer that came with it.
  • 12,061 Answers
Usually requires 12Volts
Posted on Jan 31, 2010
Flyback Transformer Spare Part Number for Sony Trinitron KV-2062E . 3109 is Engraved on the metal cradle of the original fitted flyback.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Circuit diagrams of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. LOT number can be noted there.
Jan 05, 2016 | Sony Televison & Video
Lionel legacy will not run more than 2 trains
see pages 44 & 45 of attached pdf to figure out your power requirements for all locomotives, lamps/light bulbs & accessories.
compare total needed to power output of your transformer, if total is less that output of transformer, clean wheels, roller pickups & track.
if total is greater than output of transformer, you need more power/larger output transformer. lean wheels, roller pickups track.
http://www.slsprr.net/history/1954LionelTrainsAccess.pdf
Apr 05, 2014 | Lionel Crafts & Hobbies
I don't have the transformer for the power what
For what make and model camera?
Apr 12, 2013 | Cameras
Can i use the ps21us power supply in europe without a transformer?
not unless its set up for 220volts also, some of the older models have a switch you can flip to make that change, the newer ones don't, most everything in Europe is 22volts,, they do have adapters with voltage step in them, so shop around, they can be pretty cheap depending on the wattage required.. hers a few you can check out
http://www.amazon.com/Travel-Voltage-Power-Converter-Adapter/dp/B001AHTEEU
Aug 07, 2011 | Shure Distribution Shure PS21US Power...
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
I need a transformer
Hello
It is not clear from your post, that which transformer part number you wants to know. Anyway I'm hereby send you the part numbers of it two main transformers.
[1] Horizontal Ouput Transformer, or Line Output Transformer or Flyback transformer [HOT or LOT or FBT]; Part number is (257807)
[2] Switeched Mode Power Supply transofrmer [ SMPS transformer]: Part number is (257807)
OK.
Dec 16, 2010 | RCA F36650 36" TV
Power to printer but printre will not turn on as there a reset
Are you using a volt/ohm meter to determine that the transformer is supplying power to the printer?
If so, what is the input (measured at the receptacle) to the transformer?
What is the output of the transformer and is it supplying the correct amount of voltage (output voltage requirement is normally found imprinted on the body of the transformer or in the technical specifications section of the printer's manual.
Don
Dec 01, 2009 | Canon i860 InkJet Photo Printer
Aiwa 3CD changer,Model no.CX-NK550HR, CD Player not working.CD Board is required to be renewed.Where can I get original CD board of above mentioned model
some one help me...my aiwa vcd component model no. CX-NK550HR suddenly dont open or power up... i think it have a problem in its transformer...what do u think???kindly send me a response on my problem pls.....
ym:jhongojar
email add; near.evil@yahoo.com
Nov 12, 2009 | Aiwa Audio Players & Recorders
RCA(32 inch)
It is possible to repair it yourself. Let me caution you though. There are a number of generic manufacturers that sell replacement flyback transformers at less $$ than the original. The shop is most likety using the factory original which runs in the $75 range. Figuring on a typical labor rate of $125 for a 32" set gets you to the $200 figure. Realize also, that the $200 will include any other supportive parts that may be required in all probability as well as at least a 90 day guarantee.
Dan
May 29, 2008 | RCA F32650 32" TV
AC Adapter
I own one of these, which I bought new & hardly ever used. Still have the original packaging, paperwork, discs, etc.
The transformer (original) says this:
CLASS 2 TRANSFORMER
MODEL: 48A-18-900
UL LISTED 5J62
E113827
LR87815
INPUT: 120VAC 60Hz 25W
OUTPUT: 18VAC 900mA
9702
I hope this information is helpful.
Jan 28, 2008 | Micro Solutions -166550 External 8x CD-ROM...
Iomega ZIP 100 MB SCSI (10011) External ZIP Drive Logo
69 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
