2001 Ford F250 Super Duty Super Cab Logo
Posted on Jan 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
7.3 litre diesel will start, then when hot shuts down
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 310 Answers
  • Posted on Jan 31, 2010
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
310
Questions
Helped
86518
Points
727
TPS is bad or inject pump has bad sosenr
bipfog2
Level 1:
  • Contributor 5 Answers
  • Posted on Feb 09, 2015
bipfog2
Contributor
Level 1:
Answers
5
Questions
0
Helped
1436
Points
13
Most likely the cam sensor. They are known for this. Right front timing cover.
Anonymous
Level 2:
New Friend:
  • Expert 148 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
148
Questions
0
Helped
75657
Points
414
There is no injection pump on a 7.4 litre diesel. It is girect injected. Each injector is a pump.On this vehicle I would suspect the CaM Sensor first.
  • Anonymous Jan 31, 2010
    When was last time oil was chged? Good oil is vital to the operation of this engine also check oil level
Which car is the most fuel-efficient?
1. Maruti Suzuki Ciaz SHVS Mileage - 28.09 kmpl
Tank capacity - 43 L
Range - 1208 km
Engine - Diesel SHVS, 1.3-litre, 90PS, 200 Nm, 5-speed Manual
2. Maruti Suzuki Celerio Mileage - 27.62 kmpl
Tank Capacity - 35 L
Range - 967 km
Engine - DDiS 125 Diesel, 0.8-litre, 47.60PS, 125 Nm, 5-speed Manual
3. Maruti Suzuki Baleno Mileage - 27.39 kmpl
Tank Capacity - 37 L
Range - 1013 km
Engine - 190 DDiS Diesel, 1.3-litre, 75PS, 190 Nm, 5-speed Manual
4. Honda Jazz Mileage - 27.30 kmpl
Tank Capacity - 40 L
Range - 1092 km
Engine - I-DTEC Diesel, 1.5-litre, 100PS, 200 Nm, 6-speed Manual
5. Tata Tiago Mileage - 27.28 kmpl
Range - 955 km
Engine - RevoTorq 3-cylinder Diesel, 1.05-litre, 70PS, 140 Nm, 5-speed Manual
1helpful
My pajero 2.8 turbo rattles when cold OK when hot
replace the injector tips as they are squirting and not atomising. They will also be dribbling and that is allowing fuel in before the injection time
Intermittent starting of rover 25 2 litre diesel
I take it that the diesel filter has been changed and the air filter.
The cheapest solution would be to check the priming pump on the hand primer near the diesel pump. Prime the pump and then try to start it - does this work? These things sometimes leak air.
Another would be to get your compression tested (although that should already have been done.)
Problem starting 2006 dodge
is there a question here???
Perhaps you could state what happened the last time it ran and you shut it off?
ex: Did it or has it ran hot? == Did it diesel when shutting down? what???????????????
Best regards
Ck
1helpful
Put unleaded in diesel would have been about 10 litres of each did not no straight away till engine started missing
fill it right up with diesel and run as normal,you will suffer a hot start problem until all the gas is used up or refill when down to 1/2 tank.(the US army use petrol/gas in diesel for tanks in arctic conditions,(forget all the bullsh..about draining the system....if the army can use it so HAVE i when ive put gas in a diesel car(about 50 times,really)check out the canadian army tanks,if you don't believe me.also the UK army,and the chieftan is 60 MILLION QUID.
1helpful
2answers
Truck won't crank & run when hot
the TPS senser is bad its on the injecter pump or you have a bad crank shaft sonser
Jaguar x type 2 litre diesel. how often should the glow plugs be changed?
Hi, glow plugs does not need changing unless the vehicle struggles to start in the morning or when cold. When testing the glow plugs, they should not take longer then about 5 seconds to become red hot.
Any suggestions on the 2500 hd shutting down
Maybe more info would be helpful, like gas, diesel, engine size, trans, cold, hot, morning first start,idle, driving down the road, accellerating?, coasting????????what you have checked and your results of those checks. Check eng light on? if so, codes?
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
