Question about Samsung SyncMaster 931B 19" LCD Monitor
Monitor blinks and then turns off - Samsung SyncMaster 931B 19" LCD Monitor
  • 11,361 Answers
First palce to check will be the power supply section, look for bad caps (bulging tops), post back what you find inside so we can guide you further, see example of failed SAMSUNG monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Posted on Jan 31, 2010
Vsonic flat screen monitor need blink codes
hi do you mean you are asking for the blinking codes on your viewsonic pc monitor?. usually lcd monitor for pc has no blinking codes, if your monitor just only a blinking indicator and won't turn on, you must check first the source from your pc if their is a signal to turn on the monitor. if just blinking only then won't turn on you must check the power supply of the monitor usually the main cause is bulging capacitor. just replace it with the same value and rating thanks for consulting the fixya good luck.
Feb 26, 2012 | Computers & Internet
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
Turn it on and the green light blinks but the
disconnect all the cables from the monitor except the power cable and turn it on if still the same issue the monitor has gone bad.
Mar 28, 2010 | Computers & Internet
When i turn on the monitor, the screen will not stay on...it continuously blinks and blinks and blinks. I tried turning the monitor on and off but it does not work. Any solutions??
monitor could be going bad. plug in the same computer and cable to another monitor. see what you get. same problem? use a new cable on either/both monitors see what happens. this will help you determine if the problem is in the monitor, cable or computer's video output.
Aug 30, 2009 | Computers & Internet
Monitor blinking
A possible solution may be with respect to the wrong set up of screen refresh rate.
One method is to use another monitor to set up your system for default VGA to stabalise the video card output to the common standard.
Next switch monitors to your LG and run the installation CDROM or if you do not have an installation CDROM allow your system to detect it and set up a windows default driver with a low refresh rate. When its stabalised get the correct driver from the LG website.
Jun 13, 2009 | LG L1915S 19" LCD Monitor
Switch led is continously blinking in green colour
Sounds like you don't have a stable connection. Try shutting down PC, and disconnect the monitor, and reconnect it, and turn PC back on, then turn the monitor on...
May 14, 2009 | Hitachi CM621F (White) 17 in.CRT...
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
Samsung SyncMaster 931B 19" LCD Monitor Logo
204 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
