Question about Philips 27RF50S 27" TV
Background lighting is bright screen scrolls vertically
  • 149 Answers
Hi there, you have a capacitor prob. at the vertical section., see the vertical section and repalce the electrolytic capacitor with in. do some check up, test and cleaning. ty
Posted on Feb 18, 2008
How to save battery power on kyocera hydro
Cell phones are drained by running background apps, LCD brightness etc. Here are a few tips to help you. Most importantly, batteries do loose their strength (even when fully charged). I would possibly replace the battery every 2-3 years with a name brand battery, not a generic. Also keep in mind, when your phone is charged at 100%..unplug it. Tips to save battery life To save and extend battery life, follow these steps:
Lower screen brightness and timeout duration
  1. From any home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Battery.
  4. Tap Brightness.
  5. Touch and slide the Brightness slider left to decrease the brightness setting.
  6. Tap OK.
  7. Tap Screen timeout.
  8. Select one of the following options:
  9. 15 seconds
  10. 30 seconds
Turn off Wi-Fi, Bluetooth, GPS, Portable Wi-Fi Hotspot
  2. Tap Settings.
  3. Tap Tethering & Networks.
  4. Tap Mobile HotSpot.
  5. Clear the Mobile HotSpot check box.
  6. Tap the Back key.
  7. Tap the Back key again to return to the 'Settings' menu.
  8. Scroll down to 'PERSONAL,' and then tap Location access.
  9. Clear the GPS satellites check box.
  10. Touch the Status bar and slide it down.
  11. Tap Wi-Fi to turn off.
  12. Tap Bluetoothto turn off.
Change application sync settings
  1. From any Home screen, tap the All Appsall+apps.pngicon.
  2. Tap Settings.
  3. Scroll to 'PERSONAL,' and then tap Accounts & sync.
  4. Clear the Auto-sync data check box.
  5. To reduce sync settings for individual applications, select the desired application.
Turn off background data
  2. Tap Settings.
  3. Tap Mobile data.
  4. Tap the Menu key.
  5. Select the Restrict background data check box.
Minimize use of third party applications
  2. Tap Settings.
  3. Scroll to 'DEVICE,' and then tap Apps.
  4. Select the application you want to edit.
  5. Tap Disable to turn off the application.
    Note: You can tap Uninstall instead to completely remove the application.
Toggle from 4G to 2G
  2. Tap Settings.
  4. Under 'NETWORK SETTINGS,' tap Mobile networks.
  5. Select or clear the Use only 2G networks check box.
Update to the latest software
  2. Tap Settings.
  3. Scroll down to 'SYSTEM,' and then tap About phone.
  4. Tap System updates.
  5. Tap Check now.
  6. Follow any additional prompts.
Set device to sleep when unused
  1. Press and then quickly release the Power key to set the screen to sleep mode.
  2. To activate the screen, press and then quickly release the Power key again.
Apr 24, 2014 | Boost Mobile Kyocera Hydro Smartphone
Tip
How to Change the Display Settings for your MP3 Player |
You can personalize your music player by changing the appearance of your background. This will also help you to read the screen while making the icons easier to see.Follow the instructions below to change the display settings on the device.
Instructions:
Things You'll Need:Owner's manual,mp3 player
1.Turn on your MP3 player and use your keypad to select "Setup." Push the center button on your keypad to highlight "Display" on the Setup menu.
2.Use the keypad to scroll though the languages on the Display Menu. Push the center button on your keypad to choose one.
3.Scroll down the menu to the "Brightness" options. Press the right arrow on your keypad to increase the screen's brightness, or press the left arrow to dim the screen.
4.Scroll down to the "Wallpaper" selection on your Display Menu. Use the arrows on your keypad to scroll through the different backgrounds for your MP3 player.
5.Change the icons on your MP3 player. Scroll down to "Appearance." Use the arrows on your keypad to scroll through the different icon choices.
Tips & Warnings:
Make your own background by downloading photos from your computer.Dim the brightness in low light situations to save battery power.
on Feb 10, 2011 | Audio Players & Recorders
Bright light background
What is your question? Are your pictures coming out with the background too bright? Do you want to take pictures of a subject with a bright light in the background? Something else?
Apr 27, 2013 | Canon EOS 600D Rebel T3i Digital Camera
How do I adjust screen brightness for night use?
The Power/Light is used to turn your GPS on and off as well as to adjust the background and back light. To adjust the back light press the power/light key to access the light and background menu. Use the 4 way cursor key to select light or background. Then use the left to right cursors to change the settings. Then press exit to exit the light/background menu. This should answer your question.
Mar 09, 2011 | Humminbird 1197c GPS Receiver
Vertical lines
do you have a cordless phone placed nearby?
i just had that problem, and realised it was because of the phone's frequency (scary!). i move the phone/base away from the tv, and it's fine now.
Oct 10, 2009 | Samsung HLN5065W 50" Rear Projection...
Vertical portion pixelats then forms solid vertical lines. Problem intermitent but persistant. The tv is 2 years old, if its the lcd panel is it worth repairing? I think I have the same problem with a...
Note
In some cases, there are minor defects in some parts of the screen. Points that do not light, points with
brightness different from that of the periphery, or points with color different from that of the periphery.
Some pixels will always be on or always off. Please note that this is not a malfunction. So what this says is that it's not the Plasma Cell problem, its more like a bad board inside. You will need more info like schematic and find out which area the bad part is in.
Jan 04, 2008 | JVC PD-42WX84 42 in. HD-Ready Plasma...
Vertical line up and down middle of TV screen
i think this is the called picture in jail. this might be due to 1 power supply reg.poor or filter cap dry. 2 loose or dry joint nera hor. output section or capacitor in eht section.
Sep 21, 2007 | Mitsubishi CS-35505 35" TV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Strange silhouetting and a vertical strip
If A vertical strip appears on the screen when recording a dark background or the subject is blooming or silhouetting, you need to adjust the BLC. * The contrast between the subject and the background is too great for the camcorder to operate normally. * Make the background brighter to reduce the contrast or use the BLC function while you are recording in a brighter environment. BLC (Back light Compensation) * BLC works in CAMERA/M.REC mode.B * Back lighting exists when the subject is darker than the background: 1. The subject is in front of a window. 2. The person to be recorded is wearing white or shiny clothes and is placed against a bright background; the person?s face is too dark to distinguish his/her features. 3. The subject is outdoors and the background is overcast. 4. The light sources are too bright. 5. The subject is against a snowy background. 1. Set the power switch to CAMERA mode. 2. Press the BLC button. Normal - BLC - Normal BLC enhances the subject. Notes: * When NITE PIX to set to ON, the BLC function does not work. * The BLC function will not operate in EASY mode.
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Philips 27RF50S 27" TV Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
