Question about HP Pavilion dv1000 Notebook
Hp dv1000 doesnt boot
When i turn it on no power lights come on but i here the fans come on for like 2 sec, and the quickplay lights come on but there is no video or power lights. The caps and num lock lights flash once when turning on, but all this time there is no video or power lights, while the quickplay lights stay on. thanks in advance for any help
    Brigadier General:
  • 4,088 Answers
Sounds like the battery is not being charged properly. With a voltmeter, check for voltage at the output of the charger that plugs into the computer. It should read several volts higher than the battery voltage rating. It is common for one of the wires to break just inside the plug. Radio Shack stores have a plug and cord that fits the computer, but the new wiring must be spliced into the original cord (with the correct polarity). Replacement cost for a new charger is quite high! Good luck!
Posted on Jan 31, 2010
Hp pavillion dv6910us will not boot. Power, quickplay bar, touchpad, and dvd lights turn on only then immediatly shuts down no beep codes or fan sounds are heard.
The motherboard is the problem, common in HP, sub out the ram one stick at a time and try power on each time, remove main battery as a last resort. If none of these help the main board must be replaced.
Mar 23, 2012 | HP Computers & Internet
I left my hp on the bed , running, and it is not responding ........what could be the damage
the dv and tx series are very poorly designed, they can't keep the internal electronics cool enough to run properly (even under ideal conditions they will fail in just over the warranty period) with the vents obstructed cooking your motherboard becomes a near certainty.
if you really need to get this machine to boot up again (eg to rescue files before it is completely done)
step 1 power down completely (you can hold the power to off for a few sec or unplug and pop the battery.)
once system has cooled test to see if it can boot. If the lights and fans all come on but the screen stays black... (warning u should never try this with a healthy pc) ..
then
turn on pc (lights come on but nobodies home, no boot, no post, no nothing) put the pc into a bag or case (whatever you would carry it around in should work)
let it run for about 30 min or so (it should be really hot now)
try booting again.
it might just be superstitious but i have found that holding down the f10 key while booting seems to help. good luck
and don't buy HP unless you want a half-*** product
Oct 20, 2010 | HP Pavilion dv1000 Notebook
I have an hp dv9000 and the web cam only works on yahoo instant message. how can it be made to work on it's own?
To turn on an HP webcam:
1. Go to QuickPlay (press the blue-lighted button above the F3 key (or next to the power button)).
2. When QuickPlay shows up, there is a row of six icons across the bottom of the screen: click on the second one from the left (the one with the photo-movie_reel-music_notes).
3. A window with three 'frames' shows up. On the left frame there are six items: the fifth one should say 'HP Webcam'. Click on it.
4. The webcam's blue LED light should now be turned on. There should be a rectangle with dimensions of ratio 1:2 which should show what the camera is sensing.
5. There is a row of seven buttons above that rectangle: the seventh is for taking snapshots and the sixth for recording videos.
6. Videos and pictures are saved at:
Pictures -- C:\Users\Public\Public Pictures\My Snapshots
Videos -- C:\Users\Public\Public Videos\HP Webcam
sometimes it doesnt say "hp web cam" it says "usb video device"
Jul 02, 2010 | HP Webcam
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Won't come on, tried taking out battery and that
take the cd drive out and look to see if it has grounding out marks on the back and look inside the bay
May 22, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
HP laptop stuck in quickplay mode
When Quickplay start try pressing ALT+F4
Apr 12, 2009 | HP Pavilion dv4000 Notebook
Power Issue turn on and is turns off after 2 sec
Could be a glitched battery. Turn it on without battery installed. Also, to eleviate the memory - take it out. The unit will still turn on. I have to go along with HP support, that's it's probably the mother board. Now all is not gloomy. Hp has extended their warranty on many models, Dv2000-Dv6000 to name a few. Ask for a supervisor.
Mar 21, 2009 | HP Pavilion dv1000 Notebook
No power
All lights come on HP Pavilion dv1000 but will not boot. looked at motherboard and by power connector there is a blown part the number on the board shows PD27. I need to know what thhe part is or a schematic showing
Jun 23, 2008 | HP Pavilion dv1000 Notebook
HP DV1000
Dear,
Please create new partition through FDISK and relaod fresh OS. This will work perfectly.
takecare
Baliram
India
Feb 23, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000
i have the same problem here.. i re-install windows, home premium to Xp pro sp2, and my note book model is Hp dv1000, i downloaded driver from hp site but it does't help... i can't even connect to internet.. i think i need the whole driver.. sounds did't work, and even the quick play bottom... can any one help me. thank you
Dec 26, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
