Clanking noise when pumping water out
I have a front loading washer and it is making a clanking noise when it starts to pump water out. Does that mean I need a new pump? The machine is only 1 year old!
  • 5,911 Answers
This could be an indication that you have something lodged in the drain pump reservoir and is getting caught in the pump impeller. The following link explains how to access the pump and clean:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
It doesn't take much to damage these small drain pumps. If anything remains lodged in the pump for any significant period of time it can cause irreparable damage requiring the pump to be replaced. The following link explains how to replace the drain pump (if required):
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer competitive pricing, so shop and compare.
If you still have problems, please let me know. I hope this helps you.
Posted on Jan 31, 2010
  • 12,061 Answers
Yup or that it is blocked?
Frigidaire front load washe makes an awful noise when water starts to drain
Yes normally remove the bottom panel and the pump is in the front on the right side. Some companies recommend you clean it every few months. Also some will let out water when you open it up, so have a towel ready.
Apr 14, 2014 | Frigidaire Affinity ATF7000E Front Load...
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
During the spin cycle the washer makes a loud noise and now it wont spin or drain water
If the 'loud noise' water sloshing you should first check that the pump filter isn't blocked. This sometimes stops the pump altogether. Coins, etc..If the noise is metallic it could mean bearings...Check the pump via the small door at floor level...Mind the water inside the machine. You may be able to drain first with a small hose which is inside the pump access door.....Nomess
Apr 15, 2010 | LG WM2496H Front Load
Water won't drain and it is not clogged. and it makes a clanking noise
You may have something lodged in the drain pump causing the noise you are hearing and affecting the drain pumps ability to drain. If this is a Whirlpool manufactured front loader, the following link explains how to access and check the drain pump reservoir:
If anything has been lodged in the pump for any significant period of time it can cause irreparable damage to the pump motor or impeller. If this is the case, the pump may require replacement. The following link epxlains how:
If you have any questions about this repair, or if you need additional assistance, please post back and let me know. I hope this helps you.
Jan 06, 2010 | Whirlpool GHW9400SU Front Load Stacked...
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
Front load washer makes funny noise when pump turns on
The pump sounds like it may be plugged wih a coin or something like that. If the pump is plugged it will make a funny noise. Remove the pump and clear everything out of it
Jun 07, 2009 | Frigidaire Affinity ATF6000F Front Load...
I have a Duet Whirlpool Front Load washer on the spin cycle it make a clanking sound and is now dripping waster from the bottom of machine.
your pump is going bad.the water is leaking from pump or rubber door boot that connects to tub and wher door shuts,check for tear in boot.
Mar 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Maytag Top Load Washer - clanking noise when spinning
no spin cycle or agatator movement , fill cycle and pump cycle works
May 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
