Question about iRiver X20 MP3 Player
Headphone Jack I read through the solutions to a loose headphone jack (ie soldering it back onto the PCB or cleaning it with contact cleaners/rubbing alcohol) and most of the people mention that their mp4 is past warranty. Mine is still in warranty, but it seems that the sound coming from the headphones is distorted whilst the speakers are fine, i'm wondering if this would still be covered by warranty? P.S - I am sure that the headphones are not the problem, i've tried with 3 different pairs.
Thanks James for your post I'm in Melbourne & I am now on my 3rd X20 all have had the same problem including this current ( 3rd ) one each time i've returned it it has been replaced with a brand new one looks like i'm CR Kennedy tomorrow to see what they've got to say about the problem happened yet again.
Tim
Posted on Mar 15, 2008
I have now had 2 of these units with the same issue.
I returned the first unit to the place of purchase and demanded a new one (buggered if I wanted to have a repaired unit after only owning it for a couple of weeks).
The second unit developed the same problem so it got returned as well. This time I rang the iRiver supplier and asked for a new one to be returned to the orginal place of purchase so I could swap it for a different brand.
I'm still having trouble finding a similar player that has the A-B repeat feature. Now I'm wondering if its 3 times a charm.
You should send yours back asap and ring the supplier as well.
Good luck.
James
Poor contact with ear bud jack. Can this be fixed?
You can try to clean the headphone jack with rubbing alcohol. Use a q-tip. Just moisten q-tip as you don't want lots of liquid running into your device though the alcohol will dry quickly.
If it is a loose connection, you may have to open your device and need soldering skills to fix it. Try cleaning the jack first.
Feb 22, 2016 | Eclipse T180 4gb 1.8" Touch Screen Video...
Have a cassette walkman that will only produce sound on one side of the headphones when jack is put into the outlet for the headphones. i know it's not the headphones because i've tried other ones too...i...
Hi ya
Well Aiwa stereos are very hard to open and designs to break when opening, however some models can be opening without too much issue.
So before you try to open the item, try these if you have some switch cleaner or alcohol tape head cleaner - put a little drop onto the headphone jack and insert and move around the socket just incase there is dirt on the contacts inside, also clean the tape head too just incase of the same,
if not then its an open up, sometime the solders come loose, so with a soldering iron just warm the solders up a little this may fix it.
if this does not it may be a broken part inside the jack - they can be replaced but not easy - spares can be got from ebay from china, for about 1.00gbp
hope this helps
Feb 14, 2014 | Aiwa HS-PS40 Personal Cassette Player
Jbl roxy over ear headphones ref 430 need to install new cord. how do i open cans?
Hello.
Headphone speakers stop functioning properly when the wireconnections to the speaker are broken. This problem often develops when theheadphone cord gets jerked while being worn. The solder connection might alsodetach over time if it was not properly manufactured. The wire can bereconnected to the speaker with a soldering iron to repair the headphone. Beaware, though, that headphones are not designed to be user maintained in thisfashion. In some cases, it is difficult to get to the speaker due to the casingdesign.
Instructions and tools needed
Screwdriver or butter knife (depending on headphone design),Soldering iron, Electrical solder
1 Plug in the solderingiron. It takes a few minutes for it to get warm enough to be used.
2 Unscrew the screws holdingthe headphone casing over the speakers. This step applies only to models thatuse screws in the casing.
3 Insert the end of the butterknife into the seam on the headphone ear pieces. Pry the two halves of thecasing apart. This step is performed only on headphone models that do not usescrews in the casing.
4 Touch the tip of thesoldering iron to the electrical solder. A small drop should melt onto the tipof the iron.
5 Touch the tip of the soldering iron to the end of thedetached speaker wire inside the headphone speaker cavity. Try to get an evencoating of solder around the exposed metal end of the wire. The soldersolidifies on the wire once the soldering iron is removed.
6 Touch the end of the wire tothe solder on the metal tab attached to the speaker.
7 Touch the tip of the solderingiron to where the wire and tab connect. The heat of the soldering iron meltsthe solder on the wire and tab together. This repairs the broken connectionbetween the wire and speaker.
8 Replace the speaker casingonto the headphone. It should snap back into place for models without screws Thanks.
Sep 22, 2011 | JBL Reference 420 On-and Over-Ear...
I removed the back of the case on the Magellan 4040 to change the battery. The headphone jack contacts came loose and even when I solder them back on there is no sound to the unit. Can I remove the...
look closely at the board where the headphone jack goes....are the contacts ripped off the board (it will appear brown where it should be silver) if the contacts are ripped off (which is what normally happens) then your only option is the get a traffic cradle..it will circumvent the power and sound on the board....good luck
Bill
Standing Member of G.O.T.
Aug 17, 2011 | Magellan Maestro 4040 GPS Receiver
Head phone socket intermitent and now failed. Any idea what to solder where?
the headphone jack would either be a 3 prong or a 4 prong. meaning it was either had 2 contacts on the headphone barrel or 3 contacts and the last prong being for ground. If you desolder the headphone jack you can easily determine this. Then you can goto a radio shack and pick one up for under 5 dollars. Problems that may come into play are is if they used a low profile jack over a standardized. But even if its 3.5mm or 2.5mm radio shack generally always sells them. You could also purchase them online. Most likely the cause is the contacts inside the headphone jack are no longer making contact with the barrel of the headphone plug. But if its not the headphone jack then it is possible the amp inside the unit has broken. also if you open the unit up determine if the solder on the headphone jack that makes the contact may have become cracked. If that is the case just heat up a soldering iron and make circles around the solder, but be careful not to spread the solder and cross connections.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Samsung YP-K3 MP3 Player
The headphones crackle, tried several different headphones, no better. I have to twist the end of it to get it to work. The slightest bump will make it crackle again.
This happens when the headphone jack gets rust on its surface or it is loose.
Clean the jack using a tissue paper on matchstick (or a similar thin object). Be gentle or you may destroy it!
If cleaning did not help you may need to replace the jack. Contact for repairs or if you have experience in soldering, you can purchase a replacement jack online (search ebay) and solder it in.
Jan 29, 2010 | Sanyo Audio Players & Recorders
My pioneer djm 600 mixer has a fault where the headphones are not playing properly though each ear and doesnt sound quite right it is not the earphones
do some cleaning in headphone socket by apply spray contact cleaner in it----then insert headphone jack in---out many times after applying  the spray.
Sep 18, 2008 | Pioneer DJM-600 Silver Professional DJ...
Problems with the headphone jack
you can try 2 things:
first thing:
remove the battery from the unit, if it is removable
grab some contact cleaner/rejuvinator and lightly coat a headphone plug with it, insert it into the headphone jack on the mp3 player and rotate it a few times, repeat 4-5 times.. then let everything dry for 5-10 minutes, pop battery back in and try it. if you don't have contact cleaner/rejuvinator, you can also use 70% or greater rubbing alcohol.
second thing:
if the first didn't work, you can remove the batteries, disassemble the unit, and replace the headphone jack itself. if you do not have experience with de-soldering, soldering, and potentially smd soldering techniques, i don't recommend this option. you may be able to get a local general electronics repair shop (tv/stereo) to replace the part for you for a nominal fee.
hope this helps,
trin
Nov 19, 2007 | iLO (2 GB) MP3 Player
Audio only plays from left headphone
The contacts inside the headphone jack are made of a springy metal there is one for the left and one for the right speakers. This happened to my Blackberry and I took it apart and got inside the jack block and re-sprung the contacts. It worked for me... I used a dental pick.
Nov 09, 2007 | Kingston Kpex100 Digital Media Player
Headphone jack
Try cleaning out the headphone jack with a Q-tip and a very small amount of glass cleaner or rubbing alcohol. That seemed to work for me.
Sep 21, 2007 | Samsung YP-T8 Digital Media Player
iRiver X20 MP3 Player Logo
44 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
