Question about Canon MultiPASS MP370 All-In-One InkJet Printer
Full ink but blank paper
I have a canon MP370. I got the ink cartridges refilled today, and now it doesn't print. this printer was given to me with dried out ink, so I've never actually seen it print. it goes through all the motions of printing, but the paper turns up blank. this is even after running numerous cleanings and nozzle checks. Any idea??
I have a similar problem but only with my black cartridge. If I try to type say a letter, the coloured logo prints but no text even though it sounded like it was printing. I spent an hour on the phone to canon and reached no conclusion. Very frustrating!
Posted on Mar 28, 2010
Paper is not printing
Since you are asking about a Canon Pixma ip3500, I would guess that the ink cartridge(s) is/are dried out, empty, or clogged. Try swapping out with new, fresh Canon cartridges and see if that fixes the problem.
Also, be aware that it is extremely ill-advised to use only refilled or "compatible" cartridges all the time in the case of inkjet printers (of which the Pixma line of printers is an example). The reason being that the refilled and "compatible" cartridges use plain ink while the OEM cartridges use a mix of ink and lubricants so as to keep the ink delivery system functioning to peak efficiency and help to keep the system clear of clogs. Therefore, if you have recently put in a new cartridge but it is yet another refill, swap it out for a real Canon cartridge and then try using the "clean the printer" function to try to clear out the ink nozzles. If you don't feel comfortable doing this or you are unsure how to accomplish this task, get in touch with a local computer or printer repair shop and they will gladly resolve this for you.
Jun 05, 2015 | Canon PIXMA iP3500 Printer
Cannon LBP 2900 lazer printer cartridge is refilled. than it prints blank page only.
canon 2900 printer first time refilling completed but print not coming wht is problem
Sep 12, 2012 | Canon LASER SHOT LBP-2900 Printer
How do I reset or disable the ink level indicator on the Canon mg2120?
Inkjet cartridges dried up at the nozzles. Can be dissolved by water to print again. Refill cartridges done by yourself can have dried up ink left in the cartridge to make it too concentrated. Too easy to dry up.
Jul 15, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
Copier appears to be functioning well, but page comes out blank
You actually answered your own question, you said it started fading and came out with lines missing. Looks like and could possibly be that the ink cartridge you are using wasn't as full as you thought it was, and the computer really has no idea, it's just software and i do not recall seeing sensors on the inside of the ink tank to tell the computer how much ink is in the cartridge. Try refilling the ink again or maybe a better idea is to buy a new cartridge since over time the cartridges can get contaminants in them which will block the ink from the inside of the cartridge.
Hope this helps
May 31, 2010 | Canon PIXMA MX310 All-In-One Printer
I replaced the ink cartridge and sill does not print properly
you have to take it so that they could fix it because i think there's something wrong with it from inside ?
Nov 20, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Does not print, printer head moves across the print but only black pages i only get blank pages. all the ink cartridges are full
Has the printer sat for a while without printing? Are you using a refill kit or new cartridges?
An ink cartridge will dry-up if it sits for two long. When this happens the computer will read that they are full, but in reality they are bad.
If you are using a refill kit to refill them then they are likely clogged (common problem with refilling). You can try cleaning the cartridges where they meet the paper, with a cotton swab and some rubbing alcohol.
Most likely the cartridges need replaced.
Oct 23, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Will only print in blue ink
most likely you are out of ink other than blue, try to refill the other colors or get new cartridges.
Mar 26, 2009 | Canon Office Equipment & Supplies
Printing problem with canon mp 370 printer
THE COPY OR PRINT NEEDS TO BE RESET, THE COPY OR PRINTER THINK YOU INSTALLED THE OLD CARTITAGE DID YOU REFILL THE INK ONLY, THIS MACHINE WILL NOT EXCEPT A USED CARTIASGE BUY A NAME BRAND
ROD
Feb 03, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
Printer problem
This may sound like a stupid question (and if you think so please don't be offended) but it is a problem I have ran into in the past.
The ink cartridges come with a little tab or piece of tape on the bottom of them, have you check to make sure these have been removed? If they have then try to run a diagnostic on the printer (in the software that came with the printer), check print head alignment, try cleaning the print heads. If none of these work let me know.
Mar 31, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Canon MultiPASS MP370 All-In-One InkJet Printer Logo
267 people viewed this question
old marine
old marine
