Question about IBM TotalStorage DS4000 EXP710Storage Expansion Unit (1740710) Expansion Module
DS4800 I GET A ERROR ON DS4800 WITH EXP 810 CONNECTED THE ERROR ON RECOVERY GURE IS DRIVE BYPASSED FAILED
Address kingston service center
You can download a free data recovery program for USB drives. Just google usb data recovery software. There are several to choose from.
Jan 13, 2014 | EXP Computer EXP Data Traveler 336E Modem
Iriver h340 new hard drive will not boot up
There are websites that offer data recovery from a failed drive. That would be your only option here.
Lost Data Call us now
Hard Drive Recovery Services SALVAGEDATA Recovery
May 03, 2017 | iRiver H340 MP3 Player
I am trying to installing recovery disks and keep getting drive A error
it's looking for a boot disk of some type. you should be able to bypass that on start up. or it may be looking raid drivers.
May 03, 2012 | Sony VAIO Digital Studio PCV-RX550 PC...
When I try to load my recovery cd on an old toshiba tecra 9100 I get an error message about 30% of the way through the recovery . The error msg is ' Error- extraction failed'. Is this a hardware...
Sounds like software problem. Error on extracting the file from the recovery cd to the hard drive. But to make sure, run a diagnostic test for the hard drive if the recovery cd includes that option, if not, try another recovery cd.
Hope this helps.
Jun 11, 2011 | Toshiba Computers & Internet
Ok so my sony viao vgn nr120e caught a virus. I finally ordered the recovery cds but my cd drive no longer works. I really do not want to replace the cd drive. Is there anyway to bypass the recovery cds...
Buy a 4GB (or larger) USB memory-stick.
Connect it to a different computer.
Copy all the files from the recovery-CDs onto the USB memory-stick.
Move the memory-stick to your computer, and try to install from the files on the USB memory-stick.
Oct 23, 2010 | Sony VAIO VGN-N320E Notebook
When I powered down and rebooted I got Windows Boot Manager Windows encountered a problem communicating with a device connected to your computer. This error can be caused by unplugging a removable storage...
hmm seems a lil odd it appears that maybe your internal computer hard drive is failing or that its not properly connected if its happened recently with no internal computer changes then its definitely the hard drive failing on you
Apr 22, 2017 | HP Compaq Presario SR1110NX PC Desktop
I have a DS4800 with an unknown password and it's not the default "infiniti"
Hi all i want rebuild raid in my san : IBM DS4800RAID (exp810) san fail i can't connect to metadata DS4800
Jan 22, 2010 | IBM DS4800 (181580H) Hard Drive Array
Toshiba external harddrive recovery HELP!
Well, formatting(generally quick format or complete format) won't make the data erased permanently. In your case the MOST effective way is to try some so-called data recovery software.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem! Remember - Always make Backups of your precious data!
Nov 30, 2009 | Computers & Internet
Crashed error 03-FFFF-OOOO
if that error occurs while attempting the recovery, typically it indicates a read write error on the hard drive. replace the hard drive and see if the recovery finishes.
(although i have only seen this problem with failing hard drives)
Nov 03, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
IBM TotalStorage DS4000 EXP710Storage Expansion Unit (1740710) Expansion Module Logo
272 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
