Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Ld400 starts and runs for 5or6minutes then shuts down starts to relite right away but when it lites the main burners it shuts down . i replaced the hi and low limits ,checked the flo regulator in the manifold its ok put in a new ign control but still does the same thing.all the wireing looks good because the heater is inside. it was built in 2003. its a laarslite2 low nox with analog heat controls. alsoi trieda new thermister and still the same.HELP!!!!! BOB BoBs pool service Los Angeles
  • 111 Answers
Check the flame sense wire at burner or curcuit board
Posted on Jan 31, 2010
Lennox G20 gas valve switches off then on Intermittently?
This could be a dirty flane sencor of the pressure switch check hoses are tight and not spilt , try jumping out the pressure switch see if that makes it work also check air fliter is clean .
Feb 11, 2013 | Heating & Cooling
Hi I have an xl80 the burner lite and heats up till at desired temp, after burner goes out the fan keeps on running 15 minutes or so. If I go down and shut off power switch to furnace then the fan shuts...
Hi, sounds like you have a problem with the heat anticipator in the thermostat. If you replaced the fan limit, and with it running that long after the burners shut down, it would be in your stat. If it fires up after resetting breaker, was the stat set to call for heat? If not, the stat is faulty. If you remove the front to get to the stat wires, take a jumper wire and jump from RH or RC to W. Heat will start. Let it run for a minute or so and remove wire. If the fan shuts down with in a min. or so, you will know it was the stat. Good Luck and let me know the out come!
Shastalaker7
A/C, & Heating Contractor
Feb 11, 2011 | Heating & Cooling
After the oven preheats the I can hear the clicking, but the oven will not relite therefore the temp just drops. If I shut off the stove and put the temp I want back in the stove will lite, but again after...
there is a problem w/the burner....kitchenaide is aware of these issues and the new burner should come with a new ignitor already attached to it,poor design...
Mar 06, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Unit randomly shuts down
you could re locate your therocouple away from flame
Dec 22, 2009 | Desa International CBN30T Central Heating...
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
Unit will try three times to start then shut down
Make sure the exhaust fan is running.You say it fires up and then cut off.Does the main burner come on just the pilot?If it's just the pilot then I would say you need to replace sense that senser the pilot lite.Because onces that senser the flame the main gas vavle should open.for give me for my mis spelling.
Mar 26, 2009 | Heating & Cooling
I have a problem with my heating system. It is about 10 years old and has had the ignitor, combustion blower motor, and programable thermostat replace in it's lifetime. The system worked great last year....
sounds like its not proofing flame. it has a sensor usually like a needle sticks out into the flame that tells the gas valve the flame lit and is burning so its ok to keep sending gas, if its fails to proof flame then burner shuts down, then it tries to relight 3 times then locks out on fail safe. the blower will sometimes run continually once that occurs to highlight a failed condition. every time you reset it will try again 3 times then shut down. lp gas is very dangerous, even i do not work on it as the gas acts like gasoline and lays around. not like natural gas that disperses well. if you see the flame sensor try gently cleaning it with a little emory cloth. also a loose ground can cause this. check tio be sure any green wires are snug , they actually flow volts to ground through the flame on some to proof, thats why no ground no flame. if that fails then the board is most likely problem. change wire for wire , or get generic replacemant and follow directions exactly. good luck.some ignitors act as a flamre proofer as soon as they are done igniting! rarely do they fail to perform both funtions.
Nov 20, 2008 | Heating & Cooling
Heating & Cooling Logo
213 people viewed this question
Top Lite On Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
