Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side constant 40 degrees.refreg.side 60 degrees. frost build up in freezer side in back of freezer. this problem has been constant for more than 24 hours. tom murray
  • GE Master
  • 4,654 Answers
Om I know that refrigerator and if you will follow these simple instructions we will get you solved.On the PSS26MSrss Profile/Artica. you hardly have a defrost time issue when you seee frost on the rear panel. Unplug and make sure the model number is what is listed here and I will tell you how to fix it. OK?, Sea Breeze
Posted on Jan 31, 2010
  • John Tripp
    John Tripp Jan 31, 2010
    Defrost heater click here=> WR51X10042 and defrost thermostat clickhere=> WR50X10054 will need replaced. You may also find thes parts here=>. Ge Artica Profile Technical Information
    If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, Thanks, Sea Breeze Please let me know if I was helpful.
  • John Tripp
    Well Tom, take care and if you need me I will be around, I was sort of thinking I hit this one on the head. But you never know because I have wrote people for hours to later find out they had a different model than listed, Have a good week end! Sea Breeze
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Frost in the freezer, and ice build up on back under a metal cover
Defrost issue, bad heater or bi-metal our timer, maybe board
Sep 01, 2012 | Refrigerators
Frig has suddenly become warmer than usual. Freezer is at 20 degrees and frig at 60. Tried to vacuum coils but very dificult to reach them underneath the unit. Any other hints?
what the problem most likely is a failed part of the defrost system Do you see a bunch of frost built up on the back wall of the freezer? If you do frost build up, take off the back wall of the freezer and replace the defrost heater and defrost thermostat. A hair dryer could be used to melt the built up frost from the coil behind the back wall. Another part that will cause frost build up is the defrost control, that isn't the freezer behind the back wall but instead it is part of the main computer board on the back of the refrig. I would replace heater/defrost thermostat first though, since they are the most likely to fail parts.
I hope my answer will help you to fix your refrigerator,
Gene
Aug 05, 2011 | Whirlpool GS6NBEXR Side by Side...
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Model TFX30PP purchased 9-10 years ago. The refrigerator & freezer are not cold enough. There was frost built up in the back of the freezer. We defrosted it. Plugged it back in - fridge read in the...
What you have is either a bad heater or heater bi-metal thermostat most likely. I say that since the ice box is working correctly until that frost builds up. Have you checked them. Your heater should test good for continuity(not open or bad) but the bi-metal is a different story. It is open at 50 degrees f and it only closes or carrys voltage when it is sitting in a freezer at 25f. What it does is allow power to the heater when the timer or automatic control calls for defrost. The defrost cycle is around 20 to 40 minutes and power is constantly being sent to that heater the whole time. When it gets warm enough for frost to melt 50F then that bi-metal opens up and kills the power to that heater. If that heater was to stay on it would not be purty. For the rest of the defrost cycle the coils simply rest and drip.
Jun 09, 2010 | Refrigerators
Whirlpool ED22PQ, 21.7 cubic feet. Freezer is not cold. Sounds like something is trying to "click on", but nothing happens.
unplug your freezer. Move the fridge 1 foot from the wall. Wait 15 minutes and plug again . if it works good , ok . if not you will need to call the technician who will check the starting relay and the compressor
Sep 12, 2009 | Whirlpool ET4WSKXS Top Freezer...
Side by side not getting cold
Hi. Thanks for The Question.Did You Check, The Fan in the freezer. Check that. Also Frost Build Up In Freezer. Also Pull Fridge From Wall Remove The Back Panel. Clean All Coils Thanks The Appliance Doc
Sep 05, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Sep 02, 2008 | GE GSS20IEM Side by Side Refrigerator
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Fridge not staying cold
Solo, firt make sure you do not have a build up of frost on the freezer inside panel. This would indicate a defrost problem. Your post states that the cooling problem is intermitant which leads me to believe that the automatic damper is at fault. It could have a build up of ice on it which is causing it to bind, or it could just be going bad. Your model does have the manual defrost timer which could be sticking at times, that is why I suggest checking the back freezer panel for frost buildup. Catriver..post back.
Dec 01, 2006 | Maytag MSD2732GR Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
363 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
