Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
The problem I have is we cannot get the television up the stairs. Is there parts or pieces I can't take off without damaging it.
  • 438 Answers
Now that`s a dale-ma, lol not much you can do except taking the casters of the bottom anything else and your asking for trouble
Posted on Jan 31, 2010
Hip surgery getting down and up stairs
you can rent a stairlift. stairs are the main reason people have accidents after hip surgery. Be very careful. Maybe get a double railing or something if you havent the money for a rental.
Jan 11, 2018 | Exercise & Fitness
Tectrix climbmax
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
You can find some of the information on these machines with the link above. Without knowing your model and serial number, the below link is to one of the manuals we have available on our Website. http://www.sportsmith.net/images/product_support/tectrix/Manuals/P1303103%20-%20Climbmax%20Personal%20Manual.pdf
Apr 18, 2014 | Exercise & Fitness
I have a olevia 232-S12 been stored up stairs just pluged in and screen looks like is cracked on inside try to rub out the crack gets bigger do i need new screen how much would it be ?
You are describing a damaged "panel" which is the entire front screen unit; forget this set as 1) with this brand the part will not be available and 2) if it was available the cost would be as much or more than the set cost when new.
Sorry to give you bad news but the screens on these sets are extremely fragile and even a slight blow can destroy them.
SD TECH
Apr 05, 2011 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Need to dismatle to move and can't
There are a lot of different treadmills and stairways that require specific solutions, but there are some general solutions.
You say you can't disassemble it, so try forearm forklifts, they can make a 2 person lift very manageable. Also if you have a large piece of cardboard (and once again, 2 strong people) the cardboard can be used to both provide a surface that will slide up the stairs and distribute the weight over a larger area, so you can actually put it on it's side without causing damage.
I've used this technique and it works with a little caution and muscle.
Oct 17, 2009 | Exercise & Fitness
Need to know if TV can be separted into 2 pieces
Yes it can and does come apart in 2 fairly equal sized pieces. There are some screws on the sides when removed the top half with the mirror will lift off. It may require some extra force the first time it is done but comes apart with ease after that
Feb 25, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Moved, now can't get the TV downstairs
it went down the stairs in one piece it should come up the same way
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
It fell and now won't start
Internal (concealed) damage, probably wiring or switch. may be something serious, can't tell until stripped down and follow wirng circuits from cord to motor. If the power head works then the switch and wiring is likely o.k. Need to remove cover, screws (some may be under control) and seperate halves of vac to trace wires or replace parts.
jim
Jul 31, 2008 | Miele s558 Silver Moon Vacuum
I need the nylon part that dispenses water when you press the hose trigger, for the stairs and upholsterly tools.
If you are talking about a piece in the handle of the hose, you may have to replace the whole hose asm. part number 90001336. A repairshop should be able to see if you can just the piece you need, if it is available by itself.
Apr 09, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Shampoo stairs
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture/stairs thoroughly before shampooing. Cover the stairs/furniture with a thick coat of suds. Once covered with suds, pop the suds into the fabric/carpet using your hands...working the bubbles into any heavily soiled areas with a soft brush. No need to vacuum after shampooing. There is only about 10 percent water to 90 percent air in the suds.
Then let it dry. 15 minutes to and hour depending on the amount of solution used. Hope this helps!!!
Feb 23, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
54 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
