Question about Motorola Mobility i776 Cell Phone
Turn on the phone and it says insert sim card with the sim card installed.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 61 Answers
Take the sim card out and make sure that it is not bent. Then clean the gold part by rubbing it on your shirt to make sure that there is no dust on it. If you can reach the contacts on the phone, rub your clean finger on them a couple of times to make sure that it's clean too (compressed air is best if you have it). There is only one way that a sim card can go in properly, so make sure that you put it back in right (most phones have a picture of a sim card close to where the sim slides in as a guide). If you are sure that the sim isn't damaged and you have it in correctly, and it still doesn't work, you probably need a new one.
Posted on Jan 31, 2010
5 Suggested Answers
SOURCE: insert correct sim card
i you should try a software update, you can get this from www.sonyericsson.com/support. hope this helps
Posted on Nov 21, 2007
SOURCE: Insert SIM Card
My phones displays the message Insert SIM Card even though it has the SIM Card.
Posted on May 04, 2008
  • 3 Answers
SOURCE: Sim Card Problem In LG Vu
did u put it correctley
Posted on Jul 01, 2009
urbanhookupz
  • 213 Answers
SOURCE: WHY DOES MY PHONE SAYS INSERT SIM
try taking SIM and battery out placing it back in an powering on.
If you try this and it still does not work you may need a new SIM card. Take it to a local dealer they should have a new SIM they will put your number on it and you will be back in business.
If the new SIM doesn't not work you will now know it is your Phone, which means time for a new one.
good luck
Posted on Mar 27, 2010
Insert sim card
I'm not sure what the question is you are asking concerning a "sim card" but if it's How to put a SIM card in your cell phone you need a pin to put in the hole and it will pop open, However if your question is that your phone keeps telling you to insert a SIM card then you need to turn off your phone first and then go into the place where it's at and remove the SIM card and then put it back in and then turn your phone back on.
Aug 03, 2013 | Samsung E1107 Cell Phone
How can i put sim card on my cellphone
the back of your phone and under the battry and bam there it is put your sim card right in the sim card hole
Apr 14, 2012 | LG enV3 VX9200 Cell Phone
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
How to install sim card
For most of the phone,sim card will be install at the back of your mobile phone. These are the steps on how to: 1. Turn off your mobile phone. 2. Remove the back case gently. 3. Remove the battery as well. 4. Theres instruction at the back of your phone on where to place the simcard and on how to insert it. 5. Make sure you properly inserted the sim card so you wont recieve offline mode error. 6. Plug back the battery. 7. Return the back cover. 8. Turn on your phone,then your good to go. remember that there are some phones wherein the simcard slot is on the side part of the phone. for this kind of phones,all you have to do is just lift the cover of the simcard slot then slowly insert the sim properly then turn on the phone and your good to go.
Dec 05, 2011 | Samsung Cell Phones
My phone shows "please insert
You could try to remove your sim card.
Install battery and turn on phone without sim card.
Use phone without sim card and do some operations.
This will check if you phone is working correctly.
Turn phone off and install sim card.
Made sure sim card is install correctly.
If this does not work, it could be the sim card is bad.
Jan 15, 2011 | Cell Phones
Hoe to insert/reomeve sim card?...
The position of the SIM card holder depends on your phone model. It might be placed under the battery or on the side of the phone. Before inserting/removing your SIM card, turn off your phone and make sure no charger is connected to the phone. Insert your SIM card according to the illustration that you find close to the SIM card holder.
Note: Without a SIM card, you can't make or receive calls. In some countries you can make emergency calls without a SIM card.
May 20, 2010 | Sony Ericsson Walkman® W995 Cell Phone
Phone won't turn on
Try inserting another sim card, if it doesn't boot up, then there's problem with the Handset. Clean the sim car interface and see if there's any twisted or tampered pins/interfaces, if so, try to straighten or else let the technician of the repairing do it for you.. good luck..
May 04, 2010 | Pantech C470 Matrix Smartphone
Keep saying insert SIM card
You are trying to use a SIM from another Network or Handset but your phone is LOCKED to your old network and/or to a specific SIM card and number: this is why it is asking you for the unlock code to remove the restriction. It you are no longer under contract or obligations (such as minimum total recharge amounts for apre-paid handsets), then you could try to request the unlock code from the original service provider of your handset.
As for asking to insert SIM card, make sure that the SIM is correctly and securely inserted in your handset SIM holder. Also check that the SIM is still functional by inserting it in another handset: SIM card can be permanently and physically disabled if you attempt to enter too many consecutive invalid codes (usually around 10).
Hope it helps and good luck!
Jan 25, 2010 | Nokia 7260 Cellular Phone
I changed sim card, now they both display ''Insert SIM''
try taking out both cards and popping the battery on the phone.
Wait a few minutes and then turn the phone on with no card in it.
Turn it back off when it says no card found and insert the newer card and power it back up.
It seemed to keep a memory of the blank card.
Jul 23, 2009 | Samsung Cell Phones
My samsung says insert sim card...
u should have to check your sim card nd insert a sim car in right way
Mar 03, 2009 | Samsung F210 Cellular Phone
Motorola Mobility i776 Cell Phone Logo
194 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
