Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
My new receiver is jumping around between channels, rewinding, sutting off and turning it self back on. Note NEW
  • Neoklassic1
    Neoklassic1 May 11, 2010
    You have a picture that's good. Audio too.? Even better. That means your receiving a clear signal via satellite.Next contact Dish Network establish that you have a defective receiver that needs to be replace asap, along with a brand new remote control. Good luck
  • 12,061 Answers
Well if it NEW, take it back, this is a microprocessor problem and should NOT happen especially to a new unit. Umm make sure ya remote isn't being activated..
Posted on Jan 31, 2010
Can not get fan to kick on the radator, i can jump it from relay but want kick on buy it self
The PCM -engine computer energizes the cooling fan relays , hi an low speed , according to information received from the coolant temp. sensor. an information programmed into the PCM . Usually around 221 degrees the PCM will energize the low speed relay . Is your car's temp . getting that high ? The best way to diagnose these types of problems is by hooking up a scan tool that can read engine sensor data parameters to see what the temp. of the engine is . Also a scan tool with bi-directional controls , this would be useful to see if the PCM can control the fans ! There could be DTC'S - diagnostic trouble codes stored in the PCM . Not all DTC'S turn on the MIL light , check engine etc..
Nov 12, 2015 | 2003 Chrysler PT Cruiser
HK avr 446 turns on but no sound, the two little speakers light up and just keep flashing. speakers ar hooked up right. At first you did her sound, when i was hooking up another seaker i hit the ground...
The channel on which you touched the ground has been shorted so the final amplifier from that channel failed and the entire receiver is now in protected mode.
You will have to replace it: a complicated job, that you should leave to a repair shop - take it to one and be prepared for a stiff bill, at least $200.
Mar 07, 2011 | Audio Players & Recorders
Bought it used without a manual. when turned on the channel is set to a channel that we dont receive. cant figure out how to set a new start channel.
You can access the on-screen menu by pressing the Vol+ and Vol- buttons together on the front of the TV . Alternatively use a remote and press Menu to access the menu (not all low end remotes will match the feature) An exact replacement remote is available here: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12878563535890&smodel=MS3252S&brand_pn=MAGNAVOX_MS3252S . Then use the channel up and down buttons on the TV to select menu items. If using the remote use the play, fast forward, fast rewind back and pause to go through the menus. Press Menu to go back one level in the menus.
Once you have the menu up, go to the bottom of the list to Install. Select Tuner Mode (the options are Antenna, Cable and Auto) and make sure that is set correctly. Next select Auto Program to look for all available channels or Edit Channels to change the channels you will see when you change the channel with the Channel up and down buttons.
Please note that the TV only has an NTSC (analog) tuner and must be used with a set-top box to see any channels other than the remaining low power stations that have not switched to digital.
Once you have a new channel list, the TV will remember the last state it was in. (Please note that the A/V inputs are reached by pressing Channel up or down past the tuner channels.
For more support information: see http://www.m4c.magnavox.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=TV_CONVENTIONAL_CA&sct=TV_LARGE_25_29_SU&session=20101023141840_216.49.243.113&grp=TV_GR&ctn=MS3252S&mid=Link_UserManuals&hlt=Link_UserManuals .
I hope this helps.
Oct 23, 2010 | Philips Magnavox MS3252S 32" TV
I no longer receive my local channel 9.1 (RF 9). I've tried rescanning and resetting the TV, to no avail. I've unplugged the set for a half-hour, but that didn't work either. Is there any other way to...
I have one TV that would sometimes receive one channel and sometimes not, while two other TVs received this channel just fine. We thought for a while there was a problem with the coax goin to that TV and when it was bent in such a way the reception was better. Not sure of the reason, but each TV is different in the reception of the new digital signals. Maybe watch that channel on the other TV's, or try to move the ant. cable around some?
Nov 25, 2009 | Sanyo DP32746 32 in. LCD Television
How to load new film
push the rewind button on the bottom of the camera, then turn the rewind knob to the right to rewind any film that may be in the camera. Lift the rewind knob up to open the back door. remove the film canister if there.
on the new film canister pull enough film to reach the take up spool. attach the leader to the spool and close the back door, advance the film to counter number 1. enjoy.
Oct 07, 2009 | Minolta XG-A 35mm SLR Camera
I have the same problem
no mention of speaker wire size or length but the internal thermal shut down circuit is very sensitive, if even one channel goes into thermal protection it shuts the unit down, quick fix is cans of compressed air for computers and clean the inside of dust the factory set thermal cut off is 39.1 to 43 degrees celcius with an impedence check of not less than 4 ohms, your fan trick sounds like the right start the volume setting is not absolute there fore it may be your units actual voltage, amperage wattage conversion output is at its limit, heat is electronic death take great care to avoid heat, large amps have massive heat sinks your sony is not one of them
Sep 09, 2009 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Dvr doesent work
Hi djn Collinswhen your DVR is not allowing you to pause or rewind live TV you will need tounplug the receiver for 10 seconds and allow the receiver to power back up and acquirethe signal. Then you will want to try the functions again and make sure theyare working fully.
Jun 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Channels are skipping
Turn the power off to the receiver and let it run its course. It should download a new program guide at this time. Another thing is to make sure you are on ALL SUB on the guide as opposed to a favorite self created guide.Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
Vcr trouble shooting
My VCR shuts off when I try to rewind a tape, can anyone help?
Aug 14, 2008 | Televison & Video
Receiver turns on and off in endless cycle
Its one of Three problems. The main b+ filter is defective, one of the standby power sources have a bad capacitor on the line, or theres a short in the main amp. section. Its probabvly going to cost you more then you would care to invest in a reciver thats around 5 to 6 years old. Its most likly time for you to upgrade to a suround sound dydtem with new fancy lights bells and whistles. Good Luck
Jul 29, 2006 | Onkyo TX-SV636 Receiver
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
99 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
