Question about Emerson EWL3706 37 in. LCD Television
Model lc320em81 popped and shut off, found fuse inside blown, replaced it and fuse blown when plugged in
  • 110 Answers
Definitely a power supply issue. Please seek a local repair service.
Posted on Jan 31, 2010
I found a blown fuse in my LG Plasma
Yes the main board is shorted, a very expensive repair, they only service the board not the parts on it. About $400.
Jan 25, 2012 | LG Televison & Video
Plugged in my car charger into the cigarette lighter and my navigation and radio shut off.
It sure sounds like a fuse may have blown, although the cigarette lighter fuse in most cars does not control the radio, and should have been able to handle the car charger without blowing. Take the lid off the fuse box, either under the hood or inside the car under the dash on the right side or left side of the car, and look for a blown fuse. Usually you can tell if they are blown by looking at them.....but you often have to remove them first, depending on the type of fuse used in your car. The inside of the lid may have a chart that shows which fuse controls the radio.
Good luck,
genetuck
Feb 13, 2011 | 2002 Acura MDX
When playing game, hear a pop ,screen then went blank found out fuse in plug blown replaced and fuse blew again . is there an internal fuse inside PS3
Hi...
It needs a new power supply
Find out which version you have . For example " CECHxxxxx" or whatever
Then hit Ebay and find a replacement
There's one torx bit (#8 I think) screw under the cap on the top end
Then all the other screws are philips
Apr 22, 2010 | Sony Playstation 3 (PS3) Console
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
Jan 03, 2010 | Sanyo Televison & Video
Dryer was working fine this afternoon. I tried to
Check for a blown thermal fuse. It is about one inch long and is located just inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter. A lack of continuity indicates a blown thermal fuse and it will have to be replaced. Hope this helped and best wishes.
Aug 06, 2009 | Dryers
Whirlppol model LGV6634BWO gas, no heat
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jul 26, 2009 | Dryers
Danby 1000 Watt Microwave is completely dead. Just stopped working right after heating up a dinner.
you may have just blown a fuse inside the microwave or the transformer inside has now failed and will need replacing but it will need to be looked at to see what exactly happened
electech
Nov 27, 2008 | Microwave Ovens
When t.v. is turned on, black picture and no sound.
Usually when the fuse blows its due to a component being shorted and if you increase the rating of the fuse you can cause other components in the circuit to blow. The pop you hear was most like a capacitor on the D board. The D board is no longer available from sony as its listed as discontinued. You will most likely have to have a qualified sony service tech trouble shoot the circuits on the D board to locate the short as it will be outside the scope of a do it yourself type of repair
May 16, 2008 | Sony KP-61HS10 61" Rear Projection...
Emerson EWL3706 37 in. LCD Television Logo
316 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
