Heater short cycles burner fires up won't stay on for long fan kicks on and chamber cools down and short cycle starts over again.......ther is a solid green led indicator lit up and I can't find so far what that indicates condition wise
  • 111 Answers
I take it the burner is pizo fired(electrically ignited), if so, there is a flame sence wire down by the burner that senses the flame, if it don't, it shuts everything down for a short time then tries to restart. check senser at burner or circuit board.(a little more info would've been nice)
Posted on Jan 31, 2010
Fan cycles after burner stops
When your furnace has reached desired temperature the burners will turn off but your fan will continue to blow for a couple of minutes Or in other words until it cools your fan limit switch. This switcheck is what tells your blower motor when to kick on and when to kick off.
Mar 06, 2015 | Heating & Cooling
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Miller home heater -runs but clicks off and on,off and on, during heating cycle .so far it keeps coming back on to get up to selected temp but this hickup during heating cycle, what problem does this...
If the burner comes on and then after a while the burner turns off for a short time, minute or less then starts again, you might have a problem with your fan motor or a very dirty air filter. I could be going off on high limit and then resetting and working that squence of operation. Also if your unit has been worked on recently, a larger then needed nozzel could have been installed and the unit fan can not cool the heat exchanger quick enough.
Dec 14, 2009 | Heating & Cooling
The heater heats up, the blower comes on for a minute then goes off, and continues to cycle like this
Good Morning, So, you say the heater does heat up, the fan will cycle on and shuts back down in a minute, and continues to cycle this way. A few things that will cause this. But let me ask this first, does the burners stay on through this short cycling of fan? Let me know if we don't solve it before that. I don't know if you're t-stat is programmable or a mechanical? Anyway, you have what they call a heat anticipator on stats which will cycle unit on and off like this if they have burned out. If it is a mechanical (mercury switch) type, pull the cover and you will see a small dial with numbers and a arrow on it. Set it to .4 and if its programmable, you will have to go into the program to do this. Normally it is set at factory to .4 amps and the setting varies with the amps on the gas valve as they should match. I assume you have been there for sometime and this problem has just started.I wish I knew if the burners were shutting off when the fan cycles off? This would be helpful. If the burners stay on because the fan is only off for a short time, the high Limit switch is good, because when the burners are on, and the fan comes on and shuts off and stays off, the unit will open the contacts on the high limit and shut burners off for safety. I would say that the combination fan control is sticking or failing causing your fan to short cycle. Only, if this is an older furnace though. If it is a newer one with the electronic pilot ignitor, the main control board is you're problem and will need R & Ring. Please get back to me and give me the information I have mentioned, as name, model #, serial #, and age or if it is eletronic pilot or a standing pilot(on all the time) this will help to solve this. Also, what stat you have.Try the things I mentioned, but please get back to me so we can solve you're problem. Thank you, and Sincerely,
Shastalaker7
Nov 21, 2009 | Heating & Cooling
I have a wall furnace whose fan short cycles on and off (even when the burner is still burning). I replaced the fan control switch, to no avail. Any Ideas?
Could the fan motor be heating up and shutting down on thermal overload? How long of a duration does it stay off before it starts again? Typically there is a bi-metal switch that rests on the heat exchanger and starts and stops the fan motor. If it is bad or not resting against the exchanger it will not operate as it should. Check the location of the switch. If it is touching but still cycling, test your switch with a multimeter set on Ohms. Let the heater run, jump the two wires you pulled off the switch (they are 120 volts so be careful) and watch your multimeter to see when the switch opens and closes. If it cycles as it has been, you have a bad motor. If the switch closes as the heat exchanger gets hot and stays hot as long as the heater is running, the switch is good.
Nov 06, 2009 | Heating & Cooling
A 1979 Colman RV furnace. Blower shuts off shortly after burner shuts off leaving a hot heat exchanger. After 15 seconds blower comes on again blows for 10 seconds shuts off comes on in 15 seconds blows...
The fan limiting switch is acting up. It should stay running until lower temp is reached. It will cycle until the temp stays below or at the low setting. Limit switches are adjustable.
Jun 09, 2009 | Coleman Propane Forced Air Heater...
Fan cycles on and off to often the burner stays on and the fan cy
what is happening is that the heat exchanger has to get to a certain temperature before the fan comes on that way you have warm air blowing out of the grilles and when the heat excahnger gets cool it shuts off until it warms back up again.
Jan 15, 2009 | Honeywell L4064B2236 Fan/Limit Control...
Dayton 3E227A Heating Cycle
The sensor for the thermostat is probably going bad or has bad connections. It is (or thinks it is) heating up fast and therefore shuts of the heater.
Dec 30, 2007 | Dayton (3E386) Heater
Heater kicks out
Honeywell heaters like HZ3650 have a screen on the air inlet at the back side of the heater. This screen can be partially blocked off by an accumulation of lint, etc. The lint blocks some of the air flow which may cause heat increase within the heater to the point that the safety shutoff thermostat shuts off the power. Operation is returned after a cool down period only to repeat the shut down cycle after a short period of operation. If this is the cause of the problem the screen must be cleaned.
Sep 19, 2007 | Honeywell HZ365 Ceramic Compact Heater
Heating & Cooling Logo
144 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
