Question about Kenmore 63942 Dryer
I need to know how to get to the belt on the kenmore 600 dryer
    Genius:
  • 1,122 Answers
I'am assuming it has a top filter,remove top filter,remove the 2 filter screws,pull the whole top toward you and lift up,disconnect the door switch,remove the 2 screws on the top inside front panel-your in-mike
Posted on Jan 31, 2010
Testimonial: "Thanks to Mike!!!! We are in and on our way."
Belt is broke
This video should help you.
Mar 11, 2012 | Kenmore 600 6965 Electric Dryer
I have a kenmore 600 drier. It will not start. I checked the door switch and it clicks and turns the light off when pushed. I can here a click in the timer when I push the start button.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore 600 7962 Dryer
I have a Kenmore 600 dryer, gas. It is about 2 years old. There is power but the drum spins intermittently. It will spin once or twice, make a thumping sound then stop. It sort of just happened without...
heatman101
Jul 30, 2011 | Kenmore 600 7962 Dryer
Kenmore 600 dryer thumps loadly when the drum is rotating. The dryer is less than 2 years oldl checked the belt and it looks good and not loose.. t
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them .
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please do not forget to rate me,
Thank You
Jun 03, 2010 | Kenmore 600 6962 Dryer
Kenmore 600 Dryer- suddenly stopped working
can you hear the motor running, if so then more than likely the belt broke, you need to unplug it ,remove the front cover, then top cover, then remove drum and you can start to restring the new belt
Oct 26, 2009 | Kenmore 600 7962 Dryer
Can't get my Kenmore 600 series dryer to start. Can hear it clicking at the timer when I press it, but nothing!
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 13, 2009 | Kenmore 63942 Dryer
How to convert my new kenmore 600 natural gas dryer to propane
Hi!
You will need a conversion kit for converting your dryer from natural gas to Propane. Please see this link for converting your dryer from natural gas to Propane---
Kenmore 600 natural gas dryer to propane
Please ask for further clarifications.
Please rate this solution as Fixya if found useful.
Thanks
Rylee
Mar 13, 2009 | Kenmore Dryers
Kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
Jun 06, 2008 | Kenmore 62822 Electric Dryer
Kenmore 63942 Dryer Logo
119 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
