The tv blinks 9 times and doesn't turn on - Televison & Video
  • 438 Answers
Projection TV`s have many protective circuits in them, they protect your CRT`s from damage, over voltage called x-ray, and many others, you need to have it checked before the damage is more costly your TV is not happy and needs to be checked
Posted on Jan 31, 2010
My Sony Trintron's LED Light blinks 9 times when I try to turn on the set
  1. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative). If you wish to get more details about the blinking codes to Sony brand TVs, check this link. Pull up older posts there.
Mar 04, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a 42PFP5332 which doesn't turn on. When plugging in the power the green led on the power circuit board turn for a few seconds and then blinks for 9 times. After that it blinks for 10 times
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Philips 42PFP5332D 42 in. Plasma...
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Need IR code for Hisense 32" LCD tv to program
Are you referring to the iPhone/iPad app? if yes then this is not a remote app, it's a management app made for Comcast boxes and nothing else it doesn't controls tv's.
If you are referring to the actual remote for one of the Comcast boxes then it all depends on what model of remote you have and the exact model of your tv - some will support it thru the use of a Daewoo or Samsung code, others don't.
So you have 2 options:
1 - you try every Daewoo and Samsung code you have in the manual and if that fails you do a code scan on the remote as explained in the manual:
Turn on your TV
Press the TV button on the top of the remote, then press and hold Setup until the TV light blinks twice
Enter 9-9-1 and the TV button will blink twice
Press and release 1 and the TV button will blink twice
Point the remote at the TV, press and release the Power button, then press the CH+ button multiple times until the TV turns off
Press Setup once to lock in the code and the TV button will blink twice
If even that fails - the tv doesn't shuts down - then the remote is incompatible to the tv so
2 - you get a remote that is compatible with both. The only one i could find is
http://www.logitech.com/en-us/remotes/universal-remotes/devices/6812
Jun 04, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on blinks 9 times then 1 time
I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
9 red blinks
Can you verify that its 9 blinks? There is no error code in that set for 9. also please verify that its a kdsr50xbr1
Thanks
Tim
Jun 29, 2008 | Sony KDS-R50XBR1 50" HDTV
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
