Question about Elements Of Design Plumbing
I have Hot Springs Vanguard (Model 5) and I have no heat.The water is still circulating. Both the power induucator and the ready light are blinking. I went to the breaker box and shut the power off for 5 minutes and still have the same problem.I have installed new filter and still have the same problem. In the trouble shooting section of the owners manual it is saying that it could have a heater high limit thermostat tripped or a temperature sensor problem. I also have seen some information saying that I could have a bad heater. Any information you could give me would be much appreciated. Thanks, Mike
  • 943 Answers
SOURCE: Kenmore 70 Series Dryer heats for 5 minutes then trips breaker.
Thanks for the question Your problem is with your breaker its weak and wont hold you reset it it works againfor a while Happens a lot When this happens again touch the breaker you will feel its hot also check the connections at dryer and at box where you plug your dryerin see if the prongs of the cord are lost its copper color . thanks for the question the appliance docs
Posted on Sep 11, 2008
  • 131 Answers
SOURCE: Bunn coffee maker trips the breaker
It is possible that you have a short in your limit thermostat, but most likely this is caused by small holes in your main heating element. these units start to split length ways down the element, causing a short to ground through the water. These elements are readily available at your local Bunn repair shop.
Posted on Feb 13, 2009
  • 1902 Answers
SOURCE: Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Posted on Jan 03, 2010
  • 13 Answers
SOURCE: Water Heater Keeps Going Off
Modlara, it's partially true. There is a flow control valve in the heater. In case the intake is too cold or water usage is too high this valve reduces flow volume to maintain output temperature. But not shut off the flow entirely. Too bad, 063 does not come with a remote control, otherwise it could tell you what went wrong. My guess is either the air intake or vent are some how blocked. The heater is having problem generate enough heat to keep up the temp. so the flow control valve kicks in.
Posted on Feb 12, 2010
SOURCE: Reliance 40 gal hot water heater. Model 54020RS960
Hello Bill The temp stat is a square box clipped in under the elements .Can be replaced in 5 minutes.Need a large flat screwdriver.
Posted on Oct 15, 2010
How do i open water resovor on krups oblo coffee maker
See page 8
Rinse water tank before first use.
Fill water tank with fresh, drinking water. insert
water tank to machine.
Switch machine on. Power button starts
blinking red while machine is heating up for
approx. 40 seconds. Afterwards power button
lights steady green and machine is ready.
40 sec
Push selection lever to the "HOT" position.
Machine starts rinsing.
Open locking handle and insert empty capsule
holder. Close locking handle.
Place jug under outlet.
Push selection lever to the "COLD" position.
After approx. 60 seconds push selection lever
to the "STOP" position. Empty jug and refill
Make sure that the selection lever is in "STOP"
position. Then plug the power plug into a
mains power socket.
to the "STOP" position. Machine stops rinsing
and power button blinks red for about 5
Place drip grid on drip tray. Then insert drip
tray at desired position of drip tray.
Then insert drip tray at desired position of machine.
Jul 02, 2017 | Krups Coffee Makers & Espresso Machines
My hot water light wont go out,my central heating wont come on either but I do have hot water
I'll need to know what make--model--- age of this unit is and if it's electronically controlled to help you----your question is too vague do to the enormous variety types of heating systems----I'm going under the info provided that this is a boiler with domestic hot water coil----you say central heating so this throws me off---do you heat with hot water--hydronic-----or forced hot air----if hydronic---it sounds like your circulator in not functioning----a bunch of reasons circulator has failed---aquastat's "circulator control" has failed---thermostat has failed----broken wires----plugged lines----it goes on and on----this is the best I can do with this info sorry Happy Rabbit
Apr 02, 2015 | Water Water Heaters
The taco cartridge circulator #006-BC4 was working fine. Then there was a brief power outage, now it is hot to the touch, and circulates hot water to one part of the house, but not to the other 2/3's of...
Here is a tip that I wrote about heating circulator pump problems.
It will give you the information you need to learn about your circulator pump problems and solutions for it.
Heating Circulating Water Pump Problems
Nov 06, 2010 | Taco 1/2" 006 BC4-TAC Circulator Pump/...
I have. A vanguard. Energy efficient water heater in a mobil kitchen I don't. Get any hot water
If your electric hot water heater is not working...check out this tip about electric hot water heater problems
Electric Water Heater not Working
Aug 27, 2010 | Vanguard International Vanguard 82V66-2T...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
Old Vanguard Water heater not heating.
the top element is energized until the water in the top of the tank is hot enough to satisfy the upper thermostat, then the thermostat switches and sends power to the lower element. This is done to quicken the recovery time.
Mar 05, 2010 | Water Heaters
Amtrol 41 hot water maker :not working when calling for hot water,contols are on showing temp,but tank is cold.oil fired boiler is fine,the whole system is 5 yrs old.
The problem is probably with the circulator pump or the zone valve, which ever way your water circulating from the boiler is controled.
The water needs to be moved through the boiler and the coils in the Hot water maker to heat water. If this is not happening then no water will be heated.
Check for power and then is the pump is running or the zone valve opening.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 21, 2009 | Dishwashers
No hot water. hitting reset button starts it up but keeps tripping breaker
-Did you buy it directly from Grainger? The model # is actually 82SV30-2T. The "model #" you provided is Grainger's product code.
-Is this a new installation or is this an older water heater?
-Is this wired to a 25 amp breaker. (It should be.)
-Did you re-use existing wire? If so, is it at least #10 copper? (It has to be #10 or larger to comply with code) It isn't copper-clad aluminum or cotton over rubber insulated, right? (It should not be)
-Have you re-wired the heating elements? If so, you need to restore the wiring to the way it was configured from the factory.
Let me know if you need further assistance.
May 24, 2009 | Vanguard International Vanguard 82V66-2T...
Car over heating and over flow in resouvier
Whats really gunna **** you off is the part you probably need is about 5$. Inside the radiator hose is a spring loaded "switch" that supposed to expand when it becomes hot and let radiator fluid thru. Sometimes these springs freeze up and don't let the fluid thru. IE probably your problem.
Mar 06, 2009 | 2000 Pontiac Grand Am GT
Plumbing Logo
315 people viewed this question
Top Elements Of Design Plumbing Experts
Paul Carew
Tom Chichester
Are you an Elements Of Design Plumbing Expert? Answer questions, earn points and help others
