Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Flood switch has been activated. How do I reset it?
  • 41 Answers
If u put something that was too high in the DD or did u use tablets or dishwashing liquid or dishwasher cleaners all u need to do is turn the power off , open both drawers for atleast 24/48 hours and turn back on all the water evaporates clears f1 fault , or u need to take btm drawer out nd mop up water from base ,
Posted on Jan 31, 2010
Testimonial: "Solution worked. Thanks."
Neff dishwasher continues to pump
Firstly if you haven't already you should probably check the flood switch with a multimeter, it may move freely but the contacts inside could be fused closed. Only the flood switch activates the drain full time otherwise it is directly controlled by the board so if its not the flood switch its probably the board. If the board has shorted you will likely see evidence of burnout on it.
Jul 08, 2013 | Dishwashers
Flood switch activated on dishwasher DW60CSWI
Please clarify the model number. i am assuming you have a standard height single door dishwasher. It is likely the flood switch assembly itself is faulty and giving false results. Check the base of the dishwasher - item 95 in on page 10 in this manual. The microswitch could be faulty or the spring might be stuck.
Jan 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Jul 16, 2011 | Fisher and Paykel DS602 Dishwasher
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
The flood switch has been activated on our Fisher & Paykel 2-drawer dishwasher. How do we reset the button?
Turn off the main power to the dishwasher.
I am assuming you are getting F1 error code flashing (if your drawers have LCD display) or the LEDs are flashing if you have intergrated drawers.
The flood switch is located at the base of the drawer tub. You will have to either extend the drawers out fully or take them out depending on the amount of water that would have collected at the base of the tubs. Get some towels and dry the base out. You may also need a hair dryer.
Once the flood switch dries off the drawer should work ok when you turn back the power.
The causes of the flood switch trriggering is either too much foam in detergent (use recommended detergent) or leak in water in or drain pipe.
Please remember to rate the solution if it helps or post a comment if not.
Jun 12, 2010 | Fisher and Paykel Dishwashers
Flood switch was activated
1-Need to dry out the bottom housing.
2-Unplug power cord for at least 24 hours to dry out the sensor for it resets itself.
3-Locate where is the leak and fix it.
If the leak is there, the floor sensor will be always activated every time machine starts.
Aug 24, 2009 | Dishwashers
The flood switch has been activated on my dishwasher
Remove the bottom drawer by pressing in the tabs on either side of the drawer (bottom edge towards the front).
Dry out the compartment with towels and let air dry.
Apr 11, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the...
Fisher-Paykel DD603 DishDrawer shows F1 fault code. The Flood Switch has been activated. I need instructions on how to re-set the flood switch. I have two drawers that are possitioned one above the other and the are both giving the error of the activated flood switch. Any advice or instruction is greatly appreciated.
Jul 22, 2008 | Dishwashers
I have an f1 fault on the display of the dish drawer dd-603ss which i believe is the flood switch activation would you be able to help me reset it
Have you checked that there is no water remaining in the base of the dishwasher? There is probably a float attached to a microswitch in the base of the machine. A cup of water left in the base of the washer could be enough to trip the flood activation switch.
You could try tilting the dishwasher through 45 degrees to see if there is any water left inside the base.
Mar 28, 2008 | Ariston Technologies L63SNA Stainless...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
580 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
