Question about Verizon Communications Motorola V325i Cellular Phone
Help! I'm trying to upload new ringtones to V325i with MPT, Melody editor will not start.
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
Message Alert Repetition
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
I have a motorola Hint QA30... I bought the Motorola Phone Tools for it so I can create ringtones. When it finds my phone it doesnt have melody editor... so I used my old phone to do it which is a razor....
You may need Active Sync and WMCD instead since you have a Q Series phone.
Here's the URL and please don't forget to rate me with a big thumbs up. Thanks.
https://motorola-global-portal.custhelp.com/app/answers/detail/a_id/5993/p_country_code/US
Aug 15, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Ringtones fading in by default
You can try going to Sound profiles and choose a profile: "normal" or "outdoor" etc. and make sure that the Call alert type says "Melody" instead of "increasing melody". I have noticed that mine increases the melody for the first 2 seconds even with "melody" setting.
If that does not work, maybe try editing your tones so that the volume is twice as loud at the beginning of the tone. Good Luck!
May 14, 2009 | Samsung SGH-U600
I need listen rington when someone call me.
the problem might be you have kept ur mobile phone in silent mode or the ringtone sound level may be low.pls rate me
Jan 18, 2009 | UTStarcom CDM7025 Cellular Phone
Can't use mp3's as my ringtone
Send the MP3's to yourself in a message. The MP3 should be 30 seconds or less. One you receive the MP3 that you have sent to yourself, look under OPTIONS, you should see something that will let you save it as a ringtone.
Aug 24, 2008 | Cell Phones
Take the phone to a mobile service center and ahve them reflash the firmware on the phone to correct this error...it will work.
Aug 23, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Newest razr v3 ringtones
i know this sounds some what funny but make sure the phone is not on vibrate. because there are volume settings for the phones applications. just try that.=]
Apr 01, 2008 | Motorola Mobility RAZR V3
Cannot delete ringtones
HI Below is the step by step method of how to delete your ringtones in your Motorola V3: Here is an easier way to delete the ringtones without much hassle. 1) Upload 1 mp3 rintone to your phone via MPT 2) Set ALL ringtones msg, alert etc, absolutely everything for all styles (obviously excl. silent & vibe) to the uploaded MP3 3) switch your phone off, then on again. This will update the .db files. 4) Using P2K, delete all the rintones, except for the MP3 that you uploaded, do not delete the .db files. Also, do not delete the .bas files as these are the base files for Motomixer. Set all reminders to OFF. do not EVER delete a ringtone that is currently in use by the phone. If you delete it while it is active, You will NOT be able to get into that particular tone setting. 5) Switch your phone off, then on again.
May 01, 2007 | Motorola Mobility RAZR V3
Verizon Communications Motorola V325i Cellular Phone Logo
22 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
