All i get is the message about posable failure of cdrom or hard drive failure when turning on computer i just installed a video card would that couse that message or did the hard drive just fail
  • jimmy_hernan Jan 31, 2010
    well the monitor had lines thru it and i inspected the video card the fan was broke so i put a new card in and got first a fasttrack controller not conected,Bios . so i disabled promise controller , then i got message pri master disk: smart status bad backup or replace then now all i get is possable cdrom or hard drive failure thats all it shows on screen, what are the odds of my hard drive failing the computer is 3 years
    thank you
  • 10,515 Answers
Video Card could not Cause a Hard Drive Failure. But i would Appreciate, if you could explain in Detail, what made you think that it is Hard Drive has Failed?
What Message you could see on the Screen? Why did you initially Change the Video card? Is there any Strange Noise?
Let me know, so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 31, 2010
  • taran_2005
    taran_2005 Jan 31, 2010
    Thanks for your response!!
    It could be a Hard Drive Failure. Let me give you a Couple of Guides so that you could Diagnose, if it is Hard Drive Failure or not :-
    http://www.fonerbooks.com/ide_hd.htm
    http://www.pcmech.com/article/hard-drive...
    Hope i helped you.
    Thanks
Continuous short beep when start... no boot up, already change the power supply and few rams for testing, but no change. should the motherborad or cpu fail?
processor failure does not produce beeping sounds, are you sure that your extra rams are working? try to change the video card if you have the removable one. then if you're using the built in video card, try removing the sound card and modem cards or lan cards.beeping sounds is only for ram errors and any other hardware but not limited to motherboards. by the way try to clean the slot for rams, video cards and others. this would help.
Jul 12, 2011 | Acer Computers & Internet
On button flashes yellow but wont turn on
unplug the power cable for 10secs. press the power button while its unplug to remove all the electricity in the cpu. connect the power cable and then press the button. if you hear a beeping sound when you turn on the cpu, you have a problem with the motherboard. if no beeping sound, check the 4 diagnostics lights at the back of the cpu, advtrbl5.jpgMemory modules are detected, but a memory failure has occurred.
  • If you have one memory module installed, reinstall it and restart the computer.
  • If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  • If available, install properly working memory of the same type into your computer.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance
advtrbl6.jpgA possible expansion card failure has occurred.
  1. Determine if a conflict exists by removing a card (not the video card) and then restarting the computer.
  2. If the problem persists, reinstall the card that you removed, remove a different card, and then restart the computer.
  3. Repeat this process for each card. If the computer starts normally, troubleshoot the last card removed from the computer for resource conflicts (see "Resolving Software and Hardware Incompatibilities" in the Owner's Manual).
  4. If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
advtrbl7.jpgA possible video card failure has occurred
  • If the computer has a video card, remove the card and reinstall it, and restart the computer.
  • If the problem still exists, install a video card that you know works and restart the computer.
  • If the problem persists or the computer has integrated video, see "Contacting Dell" in your Owner's Manual.
advtrb16.jpgOther failure has occurred
  • Ensure that the cables are properly connected from the hard drive, CD drive, and DVD drive to the system board.
  • If the problem persists, see "Contacting Dell" in your Owner's Manualfor instructions on obtaining technical assistance.
Feb 05, 2011 | Dell Dimension 4600 PC Desktop
HOW TO DISAASSEMBLE COMPUTER DESK TOP
If you really wanted to disassemble your desktop, first unplug your power cord. Unscrew the cover screw at the back you of computer casing under your power supply. Discharge electro static by holding both hands on the computer casing chassis around 1 minute. After discharging you can now unplug the power supply which to your motherboard, cdrom drive and hard disk drive. Unplug the video card, memory, data cable like ide or sata. Unscrew your motherboard and hard disk drive and cdrom drive. That's all have a good day!
Dec 06, 2010 | YouTube Videos
I was installing a dvd drive, unhooked main power supply in computer, now when I turn on computer it says it needs a systems reboot disc can you help
The computer can't see the hard drive. IF the hard drive is on the same IDE ribbon as the DVD then you have a jumper problem. You need to look at the old cdrom if there was one and jumper new one the same as old one. (Master, slave or cable select) Also while you were digging around inside your computer did you pull the IDE ribbon to hard drive loose from the drive or the motherboard? Are the power connectors still hooked up? Every hard drive ribbon can have one slave and one master drive. Your hard drive should be the master and the cdrom the slave. Some systems are now set to "cable select" that means that the hard drive ribbon has a master connector and a slave connector and that the device (hard drive or cdrom) becomes a master if connected to one connector or a slave if hooked to the other one. If you go into your bios setup when you turn on the computer you should be able to look an see which of the drives or cdroms is hooked up as master or slave. Some will display this information during bootup posting.
Oct 04, 2009 | Computers & Internet
OPERATING SYSTEM NOT FOUND....NO ACCESS TO CD DRIVE
Connect your external CDROM to the laptop. I think it is a USB CDROM. Enter your bios setup. In the boot device section, try to find any option which says First Boot Device -> USB CDROM. If you can set this things then the computer will be able to boot from your external cdrom.
Nov 26, 2008 | Sony VAIO GRX550 Notebook
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
Screen is blank. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Problem PROBABLE CAUSE DIAGNOSIS SOLUTION
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
No color on screen. PROBABLE CAUSE DIAGNOSIS SOLUTION
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Error reading drive A: PROBABLE CAUSE DIAGNOSIS SOLUTION
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
C: drive failure. PROBABLE CAUSE DIAGNOSIS SOLUTION
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
Compaq Presario Laptop ERROR CODES
it is a hard drive problem plz try with another hdd
Jun 02, 2008 | Compaq Presario Notebook
Installing XP on a dell computer
try to go to bios and load bios defaults, esc then save and exit. boot from the cdrom by, tapping on F12 at dell screen. at boot menu screen, choose cdrom, press enter, when you see the message, PRESS ANY KEY T5O BOOT TO CDROM, hit any immediately, that should allow you to install xp directly from the cdrom.
Feb 13, 2008 | Dell Dimension 4600 PC Desktop
Disk boot failure prompt
hi, SInce u do not have a HDD u will need to boot up from cdrom, for that in the BIOS 2nd options,change the boot up sequence first to cdrom , second to any other disk.. let me know
Dec 17, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Soyo SY-P4VDA Motherboard Problem
best thing to do is disconnect floppy, take all other board/pc card out of the computer remove cdrom, now you just have a hard drive
turn it on see where it goes. if it doesnt work try a different hard drive or just the cdrom but make sure you have boot from cdrom on in your bios.
Dec 14, 2007 | Soyo SY-P4VDA Motherboard
18 people viewed this question
jasbo
jasbo
