Installing extra hard drive
How do i do it
  • S Arjun Jan 29, 2009
    i have dvd rw &cd rw too but cd rw is not working in my system if i tried with any other system it will work i don't know what to do please help me.
  • crainm Mar 22, 2009
    i was having problems with my pci boards in my intel pentium 111. I did know the pass word. As i was poking around trying to get the computer to do anything i came accross a dark screen which was giving technical imformation and there was a place to change password, so i guessed i could do this since a friend give me the computer.,and i had his password. I peplaced the pci boards but i forgot my new password and the old one dos,nt work any more. The computer is now asking for password to run set up ,any suggestions would be appreciated. Mike
  • 983 Answers
Before opening cpu just confirm that the another harddisk is master or slave by going to BIOS set up or CMOS setup....
then open you cpu
see near the harddisk which is already connected ...
then do the following:
first you have to make jumper settings .. if the harddisk which is already connected is master then you must make the extra harddisk slave by shifting the jumper to next two pins .... about jumpers it will be defined on the harddisk label refer it....
just refer this simple dots as pins which is parallel.. ... if you want to make master then you put the jumper to this first pins parallelly if you want to make slave then put in to second pins parallely...
then
1. there will be one bus which is left empty parallel to the harddisk which is already connected... the bus will broad and it will be in white colour ... connect it to extra harddisk correctly...
2.there will one more parallel power supply which will be have 4 pins small one ... connect it to extra harddisk the yellow wire must be facing you....
then just switch on the pc and check in bios settings the extra harddisk is detected or not... if not you have not connected properly connect it properly...
Posted on Feb 18, 2008
Can I change my windows 7 computer to XP with an XP disk
yes --
But you will loose all of your files and folders when you format the hard dive to install win xp
you cannot run 2 operating systems on the one hard drive unless the hard drive is partitioned ( in effect having 2 hard drives on the one disc) as it causes massive conflicts in operation
Why any one would install an out dated , unsupported operating system like win xp in place of win 7 beats me
of course if you insist in doing it you could always install and extra hard drive in the computer and run it as an extra hard drive and install the win xp on it and still retain all of your files and folders
Sep 09, 2017 | Computers & Internet
Looking for drivers for a insten hard drive encloser
There is an excellent program called SlimDrivers
http://www.majorgeeks.com/files/details/slimdrivers.html
That will scan (in Windows) your connected hardware.
You can choose which drivers to download, after it does a scan
When installing the program always use advanced option, and untick the extras, that you don't want.
Not sure if Slimdrivers download has any extra's, but you should take that precaution with every program that you install in the future.
Rob
Jan 05, 2016 | Hard Computers & Internet
How too upgrade my computer?
You can purchase, then install extra RAM or memory either online or at Staples or any store that sells computers and parts. Also you can add another hard drive which you can also install yourself if your pc has room for an extra drive. See your pc manual, and it will tell you if you can add an extra drive. Read up on how to install, its really not hard at all to do yourself. If you have an older OS like microsoft vista or xp, you can upgrade to windows 7 or 8 by purchasing one at any computer store, even Walmart. Hope this helps! If you don't feel you can do yourself, then purchase a good computer with at least 3 or 4 gigs of RAM and at least 1 TB hard drive space, as well as a high-performance video card, and a good anti-virus program like Norton or Kaspersky.
Sep 26, 2012 | Computers & Internet
Install hard drive in hp a1310n
open your desktop..
remove the jumper on the hard drive (please check if IDE or SATA)
then insert the extra-cables for the hdd & the power.
then test.
May 10, 2010 | HP Pavilion a1310n PC Desktop
Install extra hard drive
There's no place in a notebook where you can install an extra hard drive. There isn't room. You can replace the hard drive with a higher-capacity one. Or you can get a USB external drive. I personally like the external drive idea since it gives unlimited capacity.
Feb 23, 2010 | ASUS Eee PC 1000H Laptop
Installing secondary hard drive in a gateway 5310s
in most new cases there are extra slots for extra hard drives, but as long as the ide or sata is hooked up it should work, and you can buy hardware and rig up something ,ive tested many hard drives without hooking up hardware,
the components on the hard drive should not touch other metal
Jul 19, 2009 | Gateway 5310S PC Desktop
Installation of one touch mini 4
hello, if you are adding an extra hard drive for space make sure to change the teeny jumper to the proper pins next to the connection slots on the hard drive. the jumper makes your hard drive work as a slave (extra drive) or a master (main drive). if you have a main drive allready on your comp and you dont switch the jumper the slave position the computer will not recognize it becuase of the new hard drives jumper being in the master position or pin connector.
if your installing it as a 2nd master drive you need to use your extra hard drive slot on the mother board for this to work as a secound master then you need the jumper in the master pin slot. there is a small diagram on to the hard drive info label it looks like pins and it shows you where to locate or place the jumper for either master or slave.
for a slave drive once you have placed the jumper properly then you can instal it on the same cable with the main. look at the cable it will have a main and a slave small label printon the connector or if you prefer you can use the 2nd hard drive cable on the secound slot on the mother board turn on your comp if you are going for a extra hard drive the comp should recognize it if the jumper is properly placed. when your comp is running you can check by going into (computer) and it should be there as a new drive letter
after this you may need to format the drive for use. you right click on the hard drive letter and choose format drive
hope this helps good luck with your upgrade.
Dec 10, 2008 | Maxtor Hard Drive
Hard Drives
You should be able to see the drive under either my computer in windows explorer.
Jun 14, 2008 | Gateway E-2000 Deluxe PC Desktop
Dual boot/hard drive seetings
Install first the media center on the primary harddrive with master jumpered.. when everything is working fine... then proceed to
the next harddrive. Set its jumper to slave not cable select and install xp pro, it ask you for an option to have dual boot then select the location of windows to be installed...
Hoping this helps... Fixya!!!
Feb 02, 2008 | Maxtor Hard Drive
Computers & Internet Logo
218 people viewed this question
David Payne
David Payne
