Question about ASUS P5S800-VM Motherboard
How much RAM can the Asus P5S800 Motherboard have? because i have put in 1 GB and it won't read it
  • 74 Answers
Click this link,to solve your problem
Posted on Jan 31, 2010
Xp freezes when usb hard drive pluged in
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5S800-VM&p=1&s=22
If any drivers is needed.
Try to enter the device manager, and look for faults.
It sounds like the USB ports, in the computer don't provide enough power.
Does the external HDD have its own Power supply ?
Do other USB devices work ?
Maybe the pc`s power supply is running out of power, when you connect the usb harddrive.
How much ram, do you have installed ?
I suggest at least 1 gb of ram, 2 gb is better.
What service pack have you installed ?
You need at least service pack 1, to support the usb function.
Try to run ccleaner:
http://www.piriform.com/ccleaner
And make a registry clean.
A final option could be upgradeing the bios.
If the above does not help.
You just have to be very carefull, when upgrading the bios.
If you don`t have any experience with that, let a expert do this for you.
Good luck
Feb 26, 2013 | ASUS P5S800-VM Motherboard
Wanna increase ram
Hello your mainboard supports:
2 x DIMM, Max. 2 GB, DDR RAM ,Non-ECC, Memory.
Here is the homepage:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=22&m=P5S800-VM&os=&hashedid=ZcyLktAZjt2bXqgs
The ram module/s can be bought online, or in a computershop, and cost around 80 to 100 dollars each.
Good luck
Feb 21, 2013 | ASUSTeK COMPUTER Asus P5s800-vm Rev. 1.01...
Is the ms 6540 motherboard compatible with the asus p5s800-vm
what u mean compatible? if u mean u want to change your ms 6540 to Asus P5S800-VM, then i tell u it cannot be done.
first thing that u look when to change mainboard is SOCKET type... ms 6540 have socket type 478 and asus p5s800-vm have socket type LGA775. thats mean your old processor cannot be use in asus. socket 478 is older than LGA775.
So if u want to change your mainboard for ASUS P5S800-vm, then u need to change your processor to... about RAM socket and VGA socket, ms 6540 have same type with ASUS P5S800 (DDR400) so u dont need to change your RAM and VGA (if u use external VGA)
hope this useful, regards.
Aug 18, 2011 | ASUS P5S800-VM Motherboard
Dear Expert, I have Asus motherboard P5S800-VM. Now,There is 1.5 Gb ram(512MB+1 GB).If I plug 2Gb ram (1+1), then PC is working very slowly.What can I do for this problem . ram:2x1Gb Kinsgton thanks
First verify that you are using the proper speed of RAM. Second, check the BIOS and make sure that recognizes the RAM you have installed. Sometimes you have to manually set the RAM size in the BIOS in order to get it to work. Finally, I have had several issues with Kingston RAM on different motherboards even when it is the proper type so you would want to try a different manufacturer.
Jul 08, 2011 | ASUS P5S800-VM Motherboard
I have 2 sticks of 512 MB DDR 400 pc3200 in the motherboard but when i use crucials scanner to find out what memory is compatable with my computer it shows 2 sticks of 256. This board is supposed to be...
hi
your motherboard supports following RAM only
Note: PC2100/PC1600 up to 3 DIMMs; PC3200/PC2700 up to 2 DIMMs; 1GB PC3200/2700 with 32 DDR chips up to 1 DIMM only)
Aug 04, 2010 | ASUS P5S800-VM Motherboard
Asus P5VDC-MX question about ram .
Hi
You can add one more 1GB ram module.
Max Supported RAM 2 GB Memory Type DDR2Supported RAM Speeds 400 MHz · 266 MHz · 533 MHz · 333 MHz
Jul 06, 2009 | ASUS P5VDC-MX Motherboard
In my Asus P5S800-VM motherboard, it won't accept 2 ports of RAM
Check the RAM in another machine if it worked then the RAM slot might have some problem....
Mar 30, 2009 | ASUS P5S800-VM Motherboard
1gb shows 512mb only
Your mobo is quite old and its chipset can only support a maximum of 512MB PER SIDE (technically called a bank) of a memory module. I would guess that your 1gb memory module has 8 chips that are all located on one side of the module, putting all of the 1 GB on one bank. Thus, only 512MB of your 1 gb RAM is detected and usable by your motherboard (the remaining 32 mb is most likely being used by your onboard video). You'll need to find a double sided 1 gb memory module (usually 8 chips on each side).
Mar 06, 2009 | ASUS P5VDC-MX Motherboard
I have so fat
Here the Infos about your mainboard:
ASUS P5S800-VM Allgemein MPN: 90-MBL0K0-G0EAYZ, P5S800-VM
Produkttyp: Motherboard
Formfaktor: Mikro-ATX
Breite: 24.5 cm
Tiefe: 24.5 cm
Kompatible Prozessoren: Pentium 4, Celeron D
Prozessorsockel: LGA775 Socket
Chipsatz: SiS661FX / SiS964
Maximale Busgeschwindigkeit: 800 MHz
BIOS-Typ: AMI
Storage Controller: ATA-133, Serial ATA-150 (RAID)
Prozessor Installierte Anz. (max. unterstützte Geräte): 0 ( 1 )
Speicher Unterstützte RAM-Technologie: DDR SDRAM
Installierter RAM (Max.): 0 MB / 2 GB (Max)
Unterstützte RAM-Geschwindigkeit: PC2100, PC2700, PC3200
Video Grafik-Controller: SiS Mirage
Videospeicher: Shared Video Memory (UMA)
Audio Audioausgang: Soundkarte
Signalprozessor: SiS964
Audio Codec: Realtek ALC655
Soundmodus: 5.1 Channel Surround
Kompatibilität: AC '97
Telekommunikation / netzwerk Netzwerk: Netzwerkkarte - Ethernet, Fast Ethernet
Besonderheiten BIOS-Funktionen: Wiederherstellung nach Stromausfall (Wiederaufnahme bei Verlust der Wechselspannung), DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash, Hyper-Threading-Technologie, RAID-Unterstützung, DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash
Sleep / Wake up: Wake-On-LAN (WOL), Wake on Ring (WOR)
Hardwarefeatures: ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, Jack Retasking, ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2
Produktbeschreibung des Herstellers Das P5S800-VM unterstützt die neuesten Intel Pentium 4 LGA775 Prozessoren. Mit 800Mhz FSB, 1MB L2 Cache, Hyper-Threading Technologie und Spitzenleistungen von 3.6GHz und mehr ist der LGA775 Pentium 4 einer der schnellsten Desktop Prozessoren, die es zur Zeit gibt.
Dec 31, 2008 | ASUS P5S800-VM Motherboard
I don't have mother board cd
Hi, I am confused regarding the model of the Mother board
you have:
The P5S800-VM is an LGA775 socket mother-board for a
Pentium 4 CPU.
P4-515, on the other hand, does not return any hits on the
Asus web-site search.
I think your best solution is to contact ASUS /USA:
1-888-678-3688
and talk to customer support.
They will guide you in identifying the exact motherboard you
have, so you can download the driver set from their
support site.
BTW.
I think you computer performance is very unbalanced at 256 MB.
This is not nearly enough memory to run with such a fast CPU,
(2.93 Gigs), and your machine must be terribly disk bound:
1) When your operating system runs out of semiconductor
memory, it begins to thrash to disk, which is 10 million times
slower then RAM, making the fast CPU a total waste of
money.
2) For a normal machine running Windows and a 3Gig CPU
you should have at least 1 GB of RAM, preferably 2GB
(RAM is cheap these days)
But before I put my foot too deep into my mouth, I notice that
you are running FREEDOS, does that mean you are running
DOS only (No Windows ?) for some specialized application ?
Martin
Jul 20, 2008 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard Logo
147 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
