Question about LG Washing Machines
My lg fornt load washing machine soap dispenser is filling with water
  • 129 Answers
DRAIN HOSE BLOCKED
Posted on Jan 31, 2010
Why is water sitting in soap dispenser pullout drawer?
Water remaining in soap dispenser. In front loading washers made by LG (some Kenmore too), water may remain filled in the soap dispenser after the wash cycle. This may be caused by the siphon tube being contaminated by detergent residue. To clear it, remove the siphon cover from the tube, and clean them thoroughly, making sure that all residue is removed. Replace the cover and make sure it seats properly all the way down. This will ensure that the siphon starts and continues until the dispenser tray is emptied. A small amount of water, a half inch or less, remaining is normal. There is a video on YouTube that suggests buying a new detergent tray. Try cleaning it first. There are no parts that will break or wear out under normal use.
Jul 27, 2014 | LG WM2688HWM TROMM SteamWasher
I want to clean the soap and softner holders I need a manual
http://www.retrevo.com/support/LG-WM2277H-Washers-manual/id/438ag213/t/2/
I clean mine with plain hot water and a rough towel. Then I fill the dispenser with hot water and run a light wash cycle.
Dec 31, 2010 | LG WM2277H Front Load Washer
The compartment that you put the soap in sometimes fills with water when the load is finished
THAT MEANS ONE THING. REMOVE IT AND RUN IT IN WARM WATER, CLEAN IT OF ALL SOAP FILM AND ETC. ON THE SLOT FOR THE BLEACH AND FABRIC SOFTENER, FILL WITH WATER TO THE MAX LINE, LET IT SETTLE, THEN ADD WATER TO IT AGAIN AND SEE IF IT FLOWS THROUGH DOWN TO THE BOTTOM OF THE DISPENSER.
Aug 04, 2010 | LG WM-2077C Front Load Washer
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
LG 2077 CW-has IE code issue as well as soap dispensing problems
IE is an inlet error indicating that the machine has not filled up to the correct water level within 10 minutes. Could be a bad inlet valve, low water pressure or a problem with the inlet hoses (do not use anti flood hoses with these machines, use only the included fill hoses).
It sounds like all of your problems lie with the water fill. If the dispenser compartments do not get water added to them then the soap, bleach, and/or softener will not dispense properly. Then it will still be present and may dispense on the next load instead.
It is also VERY important that you use an HE (high efficiency) detergent and the correct amount (2-3 tablespoons per load). Otherwise you could end up with oversudsing issues which can also keep the bleach from dispensing properly.
Also make sure to not use GEL bleach, GEL detergent or GEL softener as they are too heavy and will not dispense properly. If all of these recommendations do not help then there is a definite issue with the incoming water supply from the inlet valves (especially if the IE errors continue). In that case you will need a technician to check the inlet valves inside the machine.
Hope this helps, please rate my solution.
Jan 04, 2009 | LG WM-2077C Front Load Washer
Where's the soap going?
Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG front loader problem
If you remove the top cover you will see the soap dispenser unit on the left. It has a large rubber hose connecting it to the drum. If you remove two screws at the front you can free the dispenser for maintenance. You can undo the clips on the various hoses and check that they are clean.
Some people report some dripping from the soap dispenser even when the hose is unblocked. This seems to be a design fault.
Nov 04, 2007 | LG WM2277H Front Load Washer
LG WM2233H Washer
Most likely the small electric motor that moves the water injection pipe on to the various outlet mainifolds has stripped its plastic gears, afraid the only solution is a new soap dispsener assembly
Oct 01, 2007 | LG WM-2277HW Front Load Washer
Soap dispenser slow leak
Plug off the wall socket first. Remove screws to remove the top of your machine. Check to see if the rubber hoses are connected well to the dispenser chamber, if not connect them properly. Another thing could be your dispenser drawer; you could pull it out gently to clean it; or you could even use a tooth brush for access.
Sep 20, 2007 | LG WD-1080FD Front Load Washer
Washing Machines Logo
110 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
