Question about SanDisk Sansa e250 MP3 Player
How do i install rockbox in my SANSA E250R????
Because i tried,but everything i find is for the e200,but i need the install for the e250r!!!!!!!!!!
shevng
  • 175 Answers
SOURCE: 4 GB micro sd and the Sandisk Sansa e250R...
try to use other usb cable cuz' somtimes its the cable problem too low in transfering a file.
Posted on Nov 22, 2007
  • 18 Answers
SOURCE: deleting music off of my sansa E250r!!HLP ME
If you originally used rhapsody (or began in Rhapsody mode) , you have to use rhapsody to remove the songs. If that doesn't work, you can manually open the music folder by enabling "hidden folders" under "tools" -> "folder options..." -> click the "view" tab -> scroll and check "show hidden files and folders". Then go to My Computer -> Sansa e250 -> "system" -> "music" -> then delete the songs. I don't know the effects of using this method, so use it at your own risk.
Btw, Real Player should do fine as well.
Posted on Dec 28, 2007
SOURCE: Sansa e250R firmware
i had same problem, sansa made it worse
i found some good firmware on this website
it is normal e250 firmware but it works
if you want rhapsody on it this is not for you
your player will act like a normal e250 not a rhapsody e250
i will post the link when i remember it
after downloading it i put it on.
NOTE you must get the firmware updater of of sansa because the firmware is older
this firmware will allow your system to boot up correctly but it is required you download the firmware updater from sandisk.com and it will be an updated working fine e250r--
BUT BEFORE YOU DO THIS, REMEMBER THIS WILL MAKE THE PLAYER EXACTLY LIKE A BASIC E250 AND NOT LIKE A RHAPSODY E250. THE ONLY DIFFERENCE IS THAT AFTER YOU DO THIS, YOU WILL NOT BE ABLE TO HAVE SUBSCRIPTION MUSIC LIKE RHAPSODY OR WINDOWS PLAYS FOR SURE--BUT THOSE ARE LAME ANYWAY.
I WILL POST THE LINK LATER.
Posted on Mar 22, 2008
SOURCE: sansa e250R rapsody mp3 player
This is the link for E 200 and E250R Sandisk Sansa Mp3 Player
http://www.sandisk.com/DriverDownload/driverList.asp
Tested Working
Thank U
Posted on Apr 13, 2008
ThaMp3Doctor
  • 8596 Answers
Get software from Sandisk's website
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
SOFTWARE SANSA E250R
You can download the driver for your operating system from
http://www.sandisk.com/sandisk-support/driver-download-wizard
You can download the Sansa Media Converter from
http://www.megaupload.com/?d=3IPZO6Q0
Nov 14, 2010 | SanDisk Sansa e200 MP3 Player
Need software for Sansa e250R
Jul 28, 2010 | SanDisk Sansa e250 MP3 Player
Hello iwould lake to know haow can i download
Jul 19, 2010 | SanDisk Sansa e200 MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
Sansa E250R doesn't recognize a 8GB card nor does my computer
Is you E280 V1 or V2? The V1 will only recognize up to 2GB. You can find this by going to settings, info. If the firmware number starts with 1 it's a V1. V2's start with 3.
If you have a V2 place the card in a card reader to format. Format card to FAT32. If not recognized by a card reader the card may be defective.
If the player is a V1 the micro SDHC can still be used by loading RockBox firmware. But note when running RockBox the sync port will be disabled. To use port the player can still be started in the Sansa firmware but a SDHC card will not be accessible.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Apr 04, 2009 | SanDisk Sansa e250 MP3 Player
No installation CD for Sansa e250R
Hi
You can download and install the drivers from this link---
Sansa drivers
Sansa rhapasody player
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Thanks
Rylee
Mar 03, 2009 | BoxWave Corporation SanDisk Sansa e250R...
E250r shows as e200 when I plug it in to renew.
http://www.anythingbutipod.com/forum/showthread.php?t=11233
Other solutions are in the above link, make sure u follow directions for 2xxR and not the 2xx..............
How to get rid of the "synchronize to continue music subscription" message if it just appears out of nowhere on your player- this fixed mine when it gave me that message:
delete the STORE.HDS file in the system/wmdrmpd directory of your sansa (optional)
import your protected songs into WMP, and resync your protected music (with WMP) in MTP mode
play a protected song and let it rebuild the store.hds file (you will experience severe lag for about 15 seconds as it rebuilds) and the music should play.
Sep 25, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250R
how do i delete music from my mp3 player from my pc music files
Jun 12, 2008 | Audio Players & Recorders
Sansa e250R rapsody mp3 player
Tested Working
Thank U
Apr 13, 2008 | SanDisk Sansa e200 MP3 Player
If the 4gb micro SD is a high capacity SD (it will say micro SDHC on it) your player may not be able to read SDHC cards, my sansa can't because it's the 'older version' it will read 2gb and below micro SD cards though (it sucked when I found out because I had just bought a 6gb micro SDHC)
Nov 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
146 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
