Question about HP LaserJet 1600 Printer
Just purchased a used hp clj 1600. USB interface is not recognized when plugging cable into computer. Tried 2 cables and 2 computers (Vista and XP Pro). Any suggestions?
    Novelist:
  • 217 Answers
The driver for the HP colour laserjet 1600 isn't built into windows, so it won't just recognise it.
You'll need to install the printer driver first (from the driver disc that should have been with the printer, or download it from HPs website).
Make sure you start this procedur with the printer SWITCHED OFF and UNPLUGGED, and follow the instructions given by the installation routine, especially waiting for the routine to tell you to plug in/turn on the printer.
Posted on May 09, 2010
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
DCR-HC38 computer not recognizing camera
Option 1:
If you want to use the USB cable to connect the Camcarder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port. (An i.LINK is a black D shaped connector with 4 or 6 pins. The type of cable to be used will depend on the i.LINK port of your Computer. The Sony Camcorder will have the 4 pin i.LINK cable and if the computer has the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE: As the Camcorder does not support USB streaming with Vista, it is not required to use any Sony Device Driver to transfer the video to the Computer. You do not require any Drivers or Software from Sony to transfer the video from the Camcorder to the Computer using the i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If you are using a Windows XP Operating System then you have to install the USB Streaming Driver in the Computer from the supplied Software disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
Sep 28, 2009 | Sony Handycam DCR-HC38E Mini DV Camcorder
Drive not recognized under Vista Home Premium 64-bit
I have seen drives not recognized for a few reasons. Bad drives, drives not jumpered correctly or full-disk encryption was used on them. Here are my thoughts:
Try making sure that the drive is jumpered to Master. Should be a jumper on the back of the drive.
Make sure you did not encrypt the hard drive using full disk encryption.
I use an USB IDE drive enclosure when recovering customer's data using a Vista computer and have not had any issues other than the ones mentioned above.
Let us know if this helps or what you find out.
Mar 31, 2009 | HP Computers & Internet
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
Windows XP will not recognize Garmin 200W
I had the same issue. I would plug it in and it would recognize the device then it would disappear.
What I did to solve the problem was to first turn on my Gamin 200w. After it was finished loading maps then I plugged in in to the usb port. My machine recognized the device without any problems. I am running Windows Vista Home Premium. Hope that helps.
Jul 25, 2008 | Garmin nuvi 200W GPS Receiver
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Camera undetected by computer
Although I haven't had this issue with my S2 IS specifically, I have with 2 other digital cameras. The solution in both cases was to power the camera on BEFORE plugging in the USB cable.
In other words - Plug the computer end of the USB cable into the computer, do not plug the camera end in. Power up the camera in "picture view" mode, THEN plug the USB cable into the camera.
Not sure about Vista, but with XP, you should hear the familiar "Dong-ding" as the system recognizes the camera.
Nov 30, 2007 | Canon PowerShot S2 IS Digital Camera
HP LaserJet 1600 Printer Logo
138 people viewed this question
Seeker5211
Seeker5211
