Question about Linksys Wireless-G Broadband Router
I'm trying to access my wireless Linksys router to secure it.
    Problem Solver:
  • 9 Answers
First inplug power from router via the jack(not the wall outlet) and then unplug the cable going to the modem, take the blue ethernet cable that comes with router and plug into internet port now you can secure your router without worrying about internet threats. Open your web browser , in the url bar type 192.168.1.1 hit enter and a window should open, asking for username/password if you have not set one the default is admin in the username field then hit enter. If you have already password connected it and forgot password you need to unplug everything from router and then hold down reset button on back. There will be a screen that will walk you through all aspects of setup, security, firewall, wirless setup , wireless security, and it will give you a break down of all options on the right side of each window. Important to setup a passkey!!! Otherwise people can get into your network easy. once setup plug blue cable into ethernet port and modem cable into internet port. plug in power and you should be set. The cd that came with router should be first used. Do not broadcast wireless ssid and use wireless pin to connect computer.
Posted on Jan 31, 2010
Testimonial: "Yes, very helpful. I had forgotten it had a reset button in the back. It was not accepting the password I had set for it so resetting was helpful. Thx"
  • learnbyererr Jan 31, 2010
    On the window that pops up for user name and password, Put admin in the password field if you have not already set one then be sure to set it. make sure the ssid matches on your router and computer.
If you have windows 7, open your pictures file. There you will see networking . You will have to enter the 8 digit serial number located on the back of the router.
5 Suggested Answers
smeago1
  • 136 Answers
SOURCE: Linksys WRT150N
I only have 3 suggestions.
1st one is to make sure the ssid is not similar to other routers you are using on your profile. ie.(change it to a unique name)
2nd is to make sure you check the box that says broadcast your ssid.
3rd check to make sure you select the router as an access point and not adhoc or infrastructure option. Finally you can try to change the channels eg. i like channel 3 b/c it doesnt interfere with any phone lines.
good luck
smeags.
Posted on Jan 07, 2008
  • 117 Answers
SOURCE: unable to access linksys wireless router,with
Hello trinijazz,
To accomplish the setup of the router, you need to be using a computer that is connected directly, harwired, into the router itself. If you don't have two computers, use the laptop but connect it into the router using the ethernet port, and ensure that the wireless on the laptop is off.
Open up your browser window and Enter 192.168.1.1 in your browsers address bar, no HTTP or anything, just the numbers, and press enter. A login box will appear that is asking for a User Name and Password. They are both, in lower case: admin then click on Login. This will take you to the Linksys Setup screen.
You have tabs at the top/center of the screen.
1) Click on the Setup tab and verify that in the drop down box it is set to: Auto Configuration-DHCP.Then verify that the time zone at the bottom is set accordingly. Do not make changes to any other settings on this screen.
2) Click on the Wireless tab at the top. Set the Wireless Network Mode to Mixed
Then choose a Network Name. This is the connection that you will connect your laptop to wirelessly.
Set the Wireless Channel to 11-2.462ghz
At Wireless SSID Broadcast click on Enable
DO NOT EXIT THAT SCREEN
3) Directly above the box where you entered MIXED, click on the sub-tab labeled Wireless Security
Security Mode: WPA2 Personal you can use WEP but WPA2 is more secure. If your laptop has connectivity issues with WPA2, try using WEP.
WPA Algorithms: I use TKIP+AES
WPA Shared Key: This is YOUR network key. Write this down and keep it in a safe place or just remember it. You will need this when you try and connect your laptop wirelessly.
Group Key Renewal: should already be set to a default of 3600
Click on the SAVE SETTINGS button
The last thing I do is I go back through each page and if some changes weren't saved I fill in the appropriate information and click the SAVE SETTINGS button for each page. You shouldn't have to but it doesn't hurt.
Last but not least, go to your laptop ( I would recommend restarting it) and turn on the wireless. You should see your newly created network and after choosing to Connect To A Network, enter your Network Key and you should be good to go.
Hope this helps
Posted on Jul 08, 2009
  • 72 Answers
SOURCE: does not save wireless security settings
Encrypting the network blocks any unauthorized computer from accessing the network and using its broadband connection. To enable WEP on the router,
1. Open your default browser and enter the following IP address into the address bar: <http://192.168.1.1>
2. When prompted for a username and password type “admin” on password, unless you have previously changed the password of the router, and hit OK. This will bring you to the Setup page of the router.
3. Depending on the firmware of the router. Click on the WEP Key Settings button. Or you can click the Wireless tab and select Wireless Security. Or you can click the Security Tab and select Wireless.
4. From the WEP/Security Settings window, you may enable 64 or 128 bit WEP then enter your Password on the Passphrase field and click on Generate. Make sure to copy the characters on Key 1-4 on a piece of paper before you hit APPLY. You will be needing this once you enable WEP on the wireless PC’s. Also take note that if you enable 64 or 128 bit on the router, this should be the same WEP level that you will enable on the wireless cards.
To put in the network key in your wireless adapter follow the steps below:
WEP Encryption XP's Wireless Zero Configuration ( Advisable for XP PC's )
1. Go to start>Control Panel>Network Connections>Right click on the Wireless connection then click on Properties>Click on the Wireless Networks Tab
2. From the Wireless Network Connection properties window, under the Preferred network click on Add then type your SSID on the SSID field and check the box for Data Encryption then then uncheck “The Key is provided for me Automatically”
3. Type your WEP Keys on both the Network Key and Confirm Network Key field. (This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.) Then hit OK and then OK again.
4. After hitting OK a pop-up should appear on the lower right hand side saying “Connected”. Try pointing your mouse arrow on the lower double monitor icon.
5. Restart your PC
WEP Encryption using the Linksys WLAN Utility ( 98/Me/2000 )
Make sure that the WLAN utility of the Linksys adapter is already is installed. If not, you may follow follow the procedures below for "Installing the Linksys WLAN Utility"
1. Click on Start then Programs, then click on anything that says something about the Linksys Wireless Adapter. On the menu, select either WLAN Utility or Wireless Configuration Utility
2. On the lower right-hand side of your screen, double click on the Linksys Icon. This will bring up the WLAN Configuration Utility.
3. Click on the Profiles Tab. Make sure that the SSID that is set to default is your routers SSID. Highlight Default then hit Edit.
4. Select Profile Wizard. Continue to click the Next button, until you get to the Security Settings Window.
OR select Expert Mode then Next. Then click on Security Settings
5. Set the same WEP level that you have enabled on the router. ( ex. 64 or 128 )
6. Type your WEP Keys. This set of characters should be identical to the WEP Keys Settings on the router. For 64-bit WEP you should have 10 characters, for 128-bit you should type in 26 characters.
7. Hit OK then Next. On Confirm New Settings click Yes. And then click “Activate New Settings Now”
Posted on Jan 05, 2010
  • 324 Answers
SOURCE: I have a linksys wireless router WRT120n, I've
192.168.0.1 from any web page, but before you do that, go to linksys website and see if you cant get default password, they have one just for this purpose, you might have to verify that its yours, but they can give you one that will work
Posted on Sep 19, 2010
I cant put safety as
Are you trying to secure the wireless network?
For this you will need to access the router setup page and change the settings manually.
See how to secure wireless network.
If you are not able to save the settings then I will suggest you to upgrade the firmware of your router. The reset the Linksys router and reconfigure it manually.
Create a new wireless network. Change the name of the wireless network that you never used before.
Then try to connect to the new wireless network.
See How to reset Linksys router.
See Linksys router setup
Jan 22, 2012 | Linksys Wireless-G WRT54G Router
Change access code on linksys wrt100
Are you speaking about router about router log in password or Wireless network password.
If you want to change the router log in password then you can go to Administration tab and change the log in password for router setup page.
IF you want to change the wireless network security key WEP / WPA then you can change the wireless settings.
Dec 13, 2011 | Linksys RangePlus WRT100 Wireless Router
How do I make my router access secure?
look on the bottom of your router there is an ip adress, go to it and enter the password located on the same sticker the ip adress is on. Once you access this page you are in the router's setting, go to security and select the settings you want.
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
How do I secure my wireless internet? I just got a new laptop and I need to secure the wireless connection before I start using it. I have a Linksys wireless-g 2.4 GHz broadband router and I never secured...
your router has a driver cd..try to run it and set up it again in the installation process you will be prompt to insert security for your wireless lan...create your passsword and your wi-fi will be secured...
just remember your your password so that you can connect to it...
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Security
You will need to secure the wireless network. You can enable password protection on the wireless network. Do you have any computer connected to the router with the ethernet cable ? If not then you will need to connect the computer to the router . After that you can access the router set up. Once you access the router set up then you will find the wireless security. Click Here for step by step solution
Nov 17, 2009 | Linksys Wireless-G Broadband Router
My iBook wont connect to my Linksys wireless G router
try removing the passkey and security on the linksys
then enable reverse authenication, by allowing only specific MAC addresses to access the router. ( MAC FILTERING ) ONLY ALLOW
then add the MAC addresses of your IBOOK and what ever else you have..
simple and secure :)
Aug 21, 2009 | Linksys Wireless-G Broadband Router
Can not get the second laptop on the internet with the wireless
The post says he has a router "linksys wireless-g access point router" ???
If it is only an Access Point then Joed is correct you need the router to access your broadband with more then 1 PC
If you have a wireless access router then here are the instructions:-
Easy Solution (you should be so lucky)
Sometimes the value for the Wireless Key is written on the underneath of the router, look for SSID (this is the network name) and WEP or WPA key (called the encryption key)
Alternative Method
In order to find out your Wireless Network Key you must first use a cable to connect to your router.
Once connected check that you are connected to the internet by opening Internet Explorer
The address or the router is usually one of the following values:-
http://192.168.0.1
http://192.168.1.1
http://10.10.0.2
http://192.168.2.1
http://192.168.2.254
Try clicking on each and see if you get a logon box popping up
If you do, that is the correct address for your Wireless router, note it down.
If the box has the username and password completed, then click OK
If there is no value for username try "admin" and for the password try one of the following "password", "admin",
Also try nothing for the username and "admin" for the password
Sometimes the value for these are written on the underneath of the router
Once the router page is displayed, look for an item called Wireless Settings.
Next see if a further option for Wireless Security exists.
The names of these items vary from Router to Router
Once security is displayed the SSID (Network Names) and the WPA or WEP Key can be found.
If there is no security I would set it to WPA or WEP then the original computer connecting will need this value if it is connecting wirelessly
Dec 26, 2008 | Linksys Wireless-G Broadband Router
Wireless set-up
Try a different web browser, sometimes that helps
Oct 23, 2008 | Linksys Wireless-G WRT54G Router
Bad Roomate
You can do that by accessing the setup page of the router.
You can follow these steps on how to change the name and put in a security.
Checking the Wireless Settings on the Linksys Router
Step 1:
Access the router’s web-based setup page. For instructions, click here.
NOTE: If you are using Mac to access the router's web-based setup page, click here.
Step 2:
When the router’s web-based setup page appears, click Wireless.
NOTE: If the screen on your router’s web-based setup page looks different, click here.
Step 3:
Look for Wireless Network Name (SSID) and if it’s still set to "linksys", change it to something unique and take note if Wireless SSID Broadcast is set to Enable.
3698-009.png Step 4:
Click Wireless Security and take note of the current Security Mode.
3698-007.jpg If Security Mode is set to WEP:
NOTE: In this example, WEP 64-Bit is used. To know more about Wireless Security, click here.
3698-013.png If Security Mode is set to WPA:
NOTE: In this example, WPA-TKIP is used. To know more about Wireless Security, click here.
3698-015.png Step 5:
Click 3698-017.png.
Or you can go to this link. if you can see the images.
Jun 18, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
107 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
