Question about Tally MT661 Printer
Does not sense paper - Tally MT661 Printer
  • 21 Answers
The paper-out sensor can be calibrated. Press and and hold the keys LF+ENTER > 3 sec. until "Tech.Access ON" appears on the display. Then press MODE -> 1-TEST -> 2-DIAG -> 3-PrntCal -> PapOut -> ENTER. Then follow the instructions shown on the display (important: close the tractor doors whilst calibrating the paper-out condition.
Posted on Jan 31, 2010
RICOH FT-4622 paper bypass sensor does not sense the paper. empty tray indication light ON althogh paper in the tray.
Dirty or faulty sensor. Check if you can give it a good blow with a blower (if you have one) then check to see if it senses the paper. Otherwise its a dead sensor.
Dec 15, 2014 | Ricoh Office Equipment & Supplies
OKI C9800 NON PAPER SENSE ERROR
remove the toner/drums and transfer belt. on the right side is the reg rollers. there is a black arm and sensor the detects the paper weight etc there. that will control the paper sense errors, make sure it moves freeley, clear of paper, dust etc.
Jul 30, 2014 | OKI C Office Equipment & Supplies
Out of paper tray has paper
remove the use a flash light to look at the lever that senses that the paper is in the tray. That probably means that the plastic lever that senses the paper. It might be stuck, off its lever.
If that is not it, then maybe you have a sensor or motherboard issue. Make sure the entire paper tray is pushed in or it will act that way. There are like 3 sensors that have to be activated in order to think it has paper.
E
Nov 23, 2011 | HP Photosmart C6280 Printer
Trying to print using my new hp Laserjet 2420 yet being told error printing. The printer shows tray 2 is empty yet it has some papers. Is there a way to only use tray 1 if the tray 2 cannot operate...
Tray 2 paper senor not sensing the paper either it may dusty,failed or sensor flag mis placed.. verify where is the fault..Location: remove tray2 cassette, under you can observe the paper sensing flag..
Aug 30, 2011 | HP LaserJet 2420 Printer
Artia 6100 machine showing err out of paper.
hi,
ur machines paper sensing sensor have some problem. did u used the paper with black mark on the side.
remove the paper cover . u can see a black square sensor near the side of thermal printer. clean the sensor with an ear bud. do not use any solutions. then check again.
remember use good quality paper. if the black mark on the side of the paper is not perfect this problem can occur (black mark on the paper is for page count and paper sensing)
ok
Dec 23, 2010 | RTO Quinton Cardiology Atria 6100 Ecg...
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
THE PRINT FROM MY LEXMARK PRINTER IS SMALL AND I CANNOT ADJUST THIS. CAN YOU HELP PLEASE
Your printer supports a wide variety of paper sizes. See Media guidelines for illustrations of proper paper orientation. The printer determines the size paper loaded in the trays by the position of the paper guides. Make sure you adjust the guides each time you change paper sizesYour printer can automatically sense when A4, letter, legal, executive media or B5, DL, and #10 envelopes are loaded in tray1. To do this, the Auto Size Sense setting must be set to On. Your printer default was set at the factory to either the US or Non-US default with the Auto Size Sense setting On.To change the Auto Size Sense setting to Off: 1 Turn the printer off. 2 Press and hold the Go and Stop buttons and turn the printer on. 3 Release both buttons when Performing Self Test appears. 4 Press Menu> or <Menu, until the Tray 1 Auto Size message appears. 5 Press Select. 6 Press Menu> or <Menu, until Off appears on the display. 7 Press Select. To return the Auto Size Sense setting to On, repeat steps 1 through 7 but, select On during step 6.
Sep 03, 2009 | Lexmark P4350 All-In-One InkJet Printer
Hp photosmart pro B9180 does not sense paper
Hello sir; You need to clean paper pick up roller, and rubber pad(right underneath the roller) as well as paper sensor.
Jan 12, 2009 | HP Photosmart Pro B9180 InkJet Printer
How can i stop the out of paper sensing permanently(Deskjet810C)
all you have to do is make sure there is paper there or put something on the sencer to make it think ther is paper. please rate me
Dec 18, 2008 | HP DeskJet 810c InkJet Printer
Printer says out of paper when it isn't.
There should be a paper sensor somewhere either to sense paper in the holder, or to sense as a sheet is pulled into the printer. It is likely there is a plastic finger which contacts the paper, and the other end of this finger either actuates a switch or an optical sensor. Sometimes this finger can get broken, and thus the printer gives a false paper-out error. This sensor & finger may not be visible without removing covers, partial disassembly.
Mar 24, 2007 | HP DeskJet 648c InkJet Printer
122 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
