Question about Canon PIXMA MX310 All-In-One Printer
Display notification "Recommend new B-CRT." shows up on display. What does it mean?
    Genius:
  • 1,601 Answers
Brjeman:
This error indicates thast one of your ink tanks are empty.
Posted on Feb 18, 2008
Monitor does not display. it can produce program sounds
That usually means it is a faulty and really would not be worth repairing.
If you need it for a reason then i am sure you can purchase second user CRT monitors very cheaply or a new or used LED/LCD display.
Aug 26, 2013 | HP COMPAQ 7540 CRT Monitor
Toshiba m60-104 screen dark new screen new iverter
Have you tried an external monitor?
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the display shows on the external monitor that proves your video card is ok and your lcd screen is the issue. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If is shows on the external monitor, then you would have to question if the new screen and lcd inverter is bad. Just because they are new don't mean they work. Are you sure you purchased the lcd screen and inverter that is for your model?
May 23, 2012 | Toshiba Satellite M60 Notebook
The "New Message Notification" will
To remove an incorrect New Message Notification, type
Feature + # + 6 + 5
Mar 08, 2011 | NorStar M7208 Corded Phone
Nokia 7230 All incoming number not displayed plz give the setting option and solved the problem
hi
go to settings menu and select the display option.select notification option. and select the show notification option in the display settings option. if you still have problem you can restart the phone and try now. if have still have same problem you can format the phone.
thank you
Dec 17, 2010 | Nokia 7230 Cell Phone
How do I stop text showing on external display
Have you tried going to general options? I have the same phone, when I open options, there are a lot of things, on of them is External notifications, it you get ther, you'll find Display Notification Details - change it to NEVER and save. Hope it helps.
Aug 06, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Problem with image display on monitor
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133236
That should fit the bill you're asking for. However, your current video card should definitely support 1024x768 fully, even at high hz refresh rates (assuming you are using a CRT). The "waves" may be caused by your video card, but it's really hard to say.
If you have more money, I would recommend this card, as it has a higher price/performance ratio:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102730
That is probably going to be the last high-performance AGP card ever produced, as the AGP bus has been discontinued now for some time. You may need a higher-end Power Supply, however. Good luck!
Sep 03, 2008 | Nvidia GeForce2 MX (32 MB) Graphic Card
New crt
Hi there. This message on a Canon fax means that the ink is low. CRT stands for cartridge. Replace the FINE cartridge, as ink is low.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jul 02, 2008 | Canon FAX-JX200
New crt?
CRT means cartridge on a Canon fax. The FINE cartridge needs to be replaced.
Message Display
Your voice mail is probably set to send notification for the first message only. No matter how many are in there, it will only tell you once. You may be able to change the notification type, depending on your voice mail.
May 21, 2008 | Mitel Superset 4025 Corded Phone...
Canon PIXMA MX310 All-In-One Printer Logo
91 people viewed this question
old marine
old marine
