Question about Microsoft Xbox 360 Console
I loaded mass effect 2..it requested I allow a download, I did, it seemed to load ok. Now I have no sound. Have reseated all connections. Still no sound.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 79 Answers
Go to your settings, go on your storage device, go to clear cache and OK
this will clear your game update and should solve your problem if not then contact Xbox support and ask them for a factory master reset code that will reset your console so it is like the first day you bought it
Posted on Jan 31, 2010
How do I down load photo's from my Samsung 2 phone please
First make sure you have the correct USB drivers for your phone installed on your pc. Go to device manager and see if your phone or mass storage device is listed. If not, download the drivers here, http://www.samsung.com/us/support/downloads. Make sure debugging on your phone is enabled. Please refer to the following:
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > Applications > Development" and enable "USB debugging".
  2. Then drag the status bar down and tap on "USB connected".
  3. The "USB connected" screen with the large green Android icon will appear. Tap on "Connect USB storage".
A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 4.0)
  1. To set the Samsung Galaxy S2 to USB Mass Storage (MSC) mode, go into "Settings > More... > USB utilities" and tap on "Connect Storage to PC".
  2. Then plug the USB cable into the device and connect to your computer.
  4. A confirmation dialog box will appear. Tap "OK". The green Android icon will turn orange, indicating that the phone is now in USB Mass Storage mode and should now appear as USB disk drives in "Devices with Removable Storage" and be assigned drive letters.
Samsung Galaxy S2 (Android 2.3)
Jan 09, 2015 | Samsung Cell Phones
Lg washing machine is making a squeaking sound and not spinning dry. Do I need to replace the belt? 7.5kg washer model WD-1018C
check the belt tension before replacing. there should be about 1/2" deflection (play) on the longest open side of the belt.
Mar 21, 2014 | LG WM1812C Front Load Washer
Connect speakers
All power amplifiers are designed to operate with a maximum current. This is limited by a minimum speaker impedance load. Your amplifier manual will specify the minimum load on output channels. High quality amplifiers can drive speakers with a combined impedance of 2 ohms or less. To calculate your parallel load, as you have requested, use the following formula. 1/Total load = 1/mgongo speaker impedance + 1/HW-E5500 speaker impedance.
Example. If your mgongo speakers have a nominal impedance of 8 ohms and the HW-E550 speakers have a nominal impedance of 8 ohms, then the formula is 1/Answer=1/8 + 1/8
1/Answer = 2/8
1/Answer = 1/4
Answer = 4.
If your amplifier can drive a 4 ohm speaker load without clipping then you are OK.
Dec 09, 2013 | Audio Players & Recorders
In my downloaded copy of Mass Effect 2 I don' t
where did you download your copy? is it a legal copy? if its pirated then chances are the game is not a full copy or its an evaluation copy.
Apr 07, 2012 | Video Game Consoles & Games
My hotpoint washer keeps spinning for a few seconds then does nothing this is on any programme
The machines as regualar functionality should produce results Expectations. For example, the machine at power on to attain functionality takes time to generate effects requested. Depending on the type of machines effectiveness where also instruction functions requested woulsd require an enormous duration to produce results. The washer machines regualr observation performs spins per duration until entire feature request have been accomplshed. What is referenceble once pwoered on is allowing the device to perform until prompted as completed processing requested. Usually the manufacturers user guide has the speicfications of expectations either in operationality or malfunctions observations. Once installed, washer machines functionality shoul be referenced howver refering to expert suport is an alternate option.
Feb 13, 2011 | Hotpoint WMA13 Front Load Washer
Not at full power
Here are 3 things you can try:
1) Download Speedfan - you might be able to control or max out the fan speed with it installed.
2) Get a laptop cooling pad such as this.
3) Check the BIOS settings (F2 after power switch but before Windows loads) - there might be a way to disable fan speed control there - so the fan will run at full speed (noisy!)
If none of that works long term, the heatsink (between the fan & CPU) probably needs to be reseated with fresh thermal grease - a pretty tricky job on a laptop -
Feb 17, 2010 | Acer Aspire 5520-5908 Notebook
After installing Masseffect on my pc, I select play game, I get bloom and shading and a list of things that where not loaded. After I click ok. The game stops. I cant get the game to start.
Try updating the drivers of your graphics card, if that doesn't work, you might wanna go for an updated graphics card.
What's your computer configuration? And what all things are not loaded when you select play game?
Nov 22, 2009 | EA - Electronic Arts Mass Effect for...
Fable 2 for Xbox360 Loading problems..
Do you have the game installed? I've had similar problems with other games(Mass Effect being the most recent) and by reinstalling it the problem went away and i was able to progress past the load screen and the area i was stuck in.
Jul 27, 2009 | Microsoft Fable 2 for Xbox 360
Can not load youtube.com - please help...
Same thing keeps happening to me. YouTube videos seem to be down at the moment.
Jun 04, 2009 | Microsoft Internet Explorer 7
It won't connect
Seems like the Operating System (is it Windows XP) may have encountered errors loading the native drivers for your player when in MTP mode, or the Windows Media Player version on the PC your plugging your player in is Windows 9 or below. The minimum requirements of the E250 is Windows XP Service Pack 2 and Windows Media Player 10 or above. Falling short of this minimum requirement may cause your player not to be properly recognized. But assuming that the PC you're using the player with meets all the requirements, try to re-load the native driver by plugging your player to the PC and doing the following: Step 1: Right-click on the "My Computer" icon, then select "Manage". This will open the "Computer Management" window. Step 2: Left-click on "Device Manager" Your player comes in two modes -- MTP and MSC -- and is how Windows XP recognizes your player depends on which mode it is set in. To access the modes on your E250, use the menu and navigate as follows: Menu >> Settings >> USB Mode If your player is currently in MTP mode, then try this: (1) Left-click in "Windows Portable Device". You should find your E250 indicated there. Check for an error indicator on the left side of that icon. The error indicator would be yellow-colored icons displayed as "!" or "?" (2): Right-click on the E250 and select "Scan for hardware changes" or "uninstall". Both would have the same effect If your player is currently in MSC mode, then try this: (1): Left-click in "Universal Serial Bus Controller". You should find a "Mass Storage Device" there (make sure that the E250 is the only device plugged in to your PC at this time). Check for an error indicator on the left side of that icon. The error indicator would be yellow-colored icons displayed as "!" or "?" (2): Right-click on the "Mass Storage" and select "Scan for hardware changes" or "uninstall". Both would have the same effect Step 3: Unplug your E250 and plug it back in. This would force Windows to re-load the driver. 90-99% of the time, it would re-load the native drivers correctly. I hope this works.
Apr 13, 2007 | SanDisk Sansa e250 MP3 Player
Microsoft Xbox 360 Console Logo
107 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
