Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
Upgraded to windows 7 and i am unable to connect to the internet. I get a limited or no connectivity
  • 1 more comment
  • nicholefishe Jan 31, 2010
    I get a limited or no connectivity. I believe it's not getting the ip address. how can I check
  • Lou H
    Lou H May 11, 2010
    not up to speed on 7 - but in vista when this happens typical reason is the firewall is on, or in a few minor cases it was that the PC was plugged in to the router after it was booted up and it was never assigned a IP address from the router. I'd start with the IP address check from the command prompt ipconfig /all and see if you have what should be the routers ip scheme and gateway info. Keep me posted
  • Neoklassic1
    Neoklassic1 Dec 22, 2013
    Unplug modem and router... Then power up modem then after it syncs .. Then power up router.. Restart computer.. You should be able to surf web in a few minutes
    Scholar:
  • 70 Answers
I'm thinking modem/router combination. first power down modem and router. Then leaving router unplugged, power up modem, make sure it's sync up then power up router. If this is a wireless connection search for your networks name on computer/laptop..ie View wireless connection. Windows allows a automatic setup if the wireless connection is unsecured. If it is secured Windows 7 will prompt a pass phrase/ or access code. Good luck. Repeat process if necessary
Posted on Jan 31, 2010
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
Why after installing webroot on my hp pavilion with windows 7 I can not connect to Internet it says " unable to connect to proxy server" ?
The anti-virus has set up a firewall which has disabled your internet access. Go into your Webroot console and go to settings and firewall and set it to make an exception for incoming network connections.
Sep 22, 2014 | Webroot AntiVirus with AntiSpyware &...
I have an acer aspire 5684wlmi. it will not connect to the internet. even when a network cable is placed in my Virgin Media Super Hub. it says limited access. i am running windows 7. I have also been...
If your laptop was running windows XP that would explain the problem, when you upgraded to window 7 you found that some of the drivers were not supported. The only option, go into the Acer site, go to download drivers to see if your laptop supports windows 7, if no! contact customer support and the technical department.
Apr 16, 2012 | Acer Computers & Internet
Can't connect to internet
You have provided very limited info on your problem. It might be hard to give a price solution. It sounds like you can connect with another PC but not your Sylvania 7" G-Netbook PC.
Confirm the following:
Jan 01, 2011 | Sylvania G-Netbook
My Intel Fujitsu Lifebook S series S6240 upgraded to windows 7, but there are some problems. the computer cannot detect devices below and cannot be installed, no matched driver. 1. unknown device, device...
Your device drivers aren't compatible with windows 7. Can you connect to the internet via cable?? If yes run windows update, this should find updated drivers to run with windows 7
Jun 02, 2010 | Intel S6240 Notebook
I recently Upgraded from Windows XP to windows 7 when Windows 7 was finished intalling internet connection did not work. Before upgrading everything worked fine.I did troubleshooting and it said ''No...
Hi
Win 7 is extremely touchy about network drivers. I didn't see your computer model listed but you'll need to log onto your computer manufacturers support page and download the Win 7 drivers for the network. Since your internet connection doesn't work right now I'd suggest another machine, if you have one or go to your local library with a Flash Drive and download the drivers to that. Good Luck
Mar 07, 2010 | Microsoft Windows XP Media Center Edition...
I upgraded to windows 7, and now that computer
Windows 7 didn't detect your network card. Your manufactor website should have the drivers for windows 7.
Nov 17, 2009 | Linksys Wireless-G WRT54G Router
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
234 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
