Question about Apple iPhone 3G
How do I get my 3g iphone to ring more than 4 times before going to voicemail?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 52 Answers
Youll need to call att, they can extend your ringtime. It takes them two minutes and its done.
Posted on Jan 31, 2010
I need to change the greeting of Iphone 3. Where to go?
I'm assuming you mean the voicemail greeting message.
iPhone 3GS How to Change Your Voicemail Greeting GROK Knowledge Base
This article should help. Has step by step instructions on how to change your voicemail greeting on your iPhone 3.
How to Record Voicemail Greeting for Your iPhone
Here's another step by step guide.
Hope this helps!
Feb 02, 2016 | Apple iPhone 3G
Goes to voice main on first try on second try rings
According to iPhone faq.org: " How can set the number of rings on my iPhone before voicemail picks up?
You can set the iPhone to wait longer or shorter than the default 20 seconds before it goes to voicemail when receiving an incoming call. This will result in a different number of rings before the voice messaging system picks up the line and plays your outgoing message. To change the amount of time the iPhone will ring follow these steps:
1. Open the phone app and dial *#61# on the Keypad. Press the Call button.
2. Locate this text on the screen: "Setting Interrogation Succeeded, Voice Call Forwarding, When Unanswered, Forwards to +" and record the 11-digit number after the + symbol.
3. Touch the Dismiss button. Now enter this code on the Keypad: *61*+ followed by the 11-digit Forwards to number recorded in step 2, followed by *11 and *ringtime#. Ringtime is the number of seconds you want your iPhone to ring before voicemail picks up. Your finished code should look something like this:
*61*+18555513466*11*30#
In the example above the ring time is set to 30 seconds. Press the Call button.
4. You should receive the message: Setting Activation Succeeded. Press Dismiss and next time you receive a call it will ring for the new amount of time before going to voicemail."
According to Apple Tool Box.com: "having this problem, please try the followings:
  • Make sure that iPhone's Ring/Silent switch is OFF meaning ringer is ON. A bell will flash briefly on the screen when you turn on the ringer.
  • Make sure that the Do Not Disturb setting is not silencing calls (Settings > Do Not Disturb).
  • Make sure that Airplane Mode is OFF (Settings > Airplane Mode).
  • Make sure that your carrier software is up to date (Settings > General > About)."
    AccorA
Apr 15, 2015 | Apple iPhone 4S
How to extend ring tone on I phone 4?
Contact your carrier's customer service. Ask them to set the maximum time before shunting the call to voicemail. They deal in time rether than number of rings. On my AT&T iPhone, the default was 20 seconds and they increased it to their maximum of 30 seconds.
Jul 09, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Iphone no display no ringing
Open the battery and see if the wires are disconnected. Otherwise, take it in to your phone service people and have them check it.
Dec 04, 2017 | Apple iPhone 3G
Increase the number of rings on iphone
http://www.fixya.com/support/r8598373-set_iphone_others_many_rings_before
By default, the iPhone rings 15 seconds before going to voicemail.
1. Figure out your voicemail access number. Dial *#61# and then press Call on your iPhone's keypad. The first block of text you'll see on the screen that comes up will be:
When Unanswered
Forwards to +1XXXXXXXXXX Enabled
Where +1XXXXXXXXXX is shown as an actual number - write this number down because you'll need it in the next steps.
2. Dial *61*+1XXXXXXXXXX*11*tt# where +1XXXXXXXXXX is the number you wrote down from the first step above and tt is the length of time in seconds for which you want your iPhone to ring. To get the + sign to show up, hold down the 0 key for a couple of seconds and release it when it turns into the + sign in the readout above. Then press Call.
Jan 20, 2012 | Apple iPhone 3G
Set number of rings before voicemail iphone
This procedure allows your iPhone to ring for longer or shorter periods than the default setting of 20 seconds before voicemail answers. *** Attempt at your own risk but if you pay attention to the keys you input and follow the directions you should have no problems.
1. On your phone, dial *#61# and click Call
The screen will display:
When Unanswered
Forwards to +1xxxYYYzzzz
Enabled
2. Write down the xxxYYYzzz number (including +1) - this is the number to your voicemail.
3. In order to make the + appear on the keypad in the next step you'll have to hold Zero down for a few seconds, then it will become a Plus (+). Dial **61*+1xxxYYYzzzz**30# and hit Call. +1xxxYYYzzzz is the number you wrote down previously, 30 is the delay in seconds. The delay can be set in 5 second increments, 30 is maximum.
4. Dial *#61# to verify that the new settings are active.
5. Verify working voice mail.
If you find you or your contacts are not being forwarded to your voice mail you have incorrectly altered your voice mail forward number.
To find out what it is and try again:
Dial ##002# and send. This will reset that forward number to factory defaults.
By then Dialing *#61# you will again display the your current (default) voice mail forwarding number.
Return to step [2] and continue.
*** Use this tutorial at your own risk ***...and if you have the time you can always give AT&T a call to have them change the number of rings on an incoming call before Visual Voicemail kicks in. I was able to quickly change the duration on my own, using these diagnostic iPhone GSM codes. The default time duration before Visual Voicemail intercepts the call is set by AT&T to 20 seconds. You will be able to add another 10 seconds yourself, but if you want your callers to wait more than 30 seconds before voicemail picks up then you'll need to contact AT&T technical support - they can change the duration to 45 seconds upon request.
Dec 19, 2010 | Apple iPhone 3G
Phone only rings a couple of times then goes to voicemail. How do I make it ring longer?
Go to call settings. Choose call divert. Select do not divert calls. Press OK
Nov 18, 2009 | Apple iPhone 3G
Iphone going straight to voicemail without ringing
goto settings, mail, fetch new data, turn off push.
Jul 10, 2009 | Apple iPhone 3G
Voicemail does not work all the times
call 1-800-331-0500 press 3 for voicemail and then 3 again to reset it. that should do the trick
Jul 22, 2008 | Apple iPhone Smartphone
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Jul 14, 2008 | Apple iPhone 3G
Apple iPhone 3G Logo
163 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
