Question about Brother HL 1440 Laser Printer
I upgraded to Windows 7 and now my HL 1440 printer will not print after I installed it. How can I fix it?
    Sniper:
  • 60 Answers
How do I clear the memory from my Brother HL-1440 printer?
Printer memory will clear if you simply unplug it from the wall. More likely, the old document was in your computer's disk, and you can control what prints from there.
Sep 11, 2014 | Brother HL-1440 Laser Printer
Looking for new printer driver for brother hl 1440 and windows 7
As per the printer manufacturer website, Brother Hl-1440 printer is not compatible with Windows 7.
http://www.brother-usa.com/Printer/ModelDisclaimer.aspx?Model=HL1440#SysReqs
However, you may download & try installing the XP drivers for the printer in Windows XP mode.
To install in compatibility mode:
1.a. Right click on the setup file of the driver.
b. Click Properties.
c. Click Compatibility tab.
d. Under compatibility mode, check mark "Run this program in compatibility mode for:" and select "Windows XP (Service Pack 2)" from the drop down list.
e. Click Apply and then click ok.
2. a. Under "Privilege level", click "Run this program as an administrator".
b. Click apply and then click ok.
3. Install the driver successfully and restart the computer for the changes to take effect.
Jun 07, 2012 | Brother HL 1440 Laser Printer
I need drivers for my brother hl-1440 printer, os system is windows 7
You can download driver from below link
click here
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 11, 2010 | Brother HL 1440 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
Brothers Hl 1440 memory upgrade
Assuming that you have the Brother HL-1440, your printer comes with 2MB installed. You may upgrade it up to 32MB maximum. However, your printer appears to use SIMM memory modules. The specs for the printer should be:
Speed: 60-80 nsec
Pin: 72-pin
Output: 32 or 36 bit
To install the memory:
1. Turn off the printer an dunplug the power cord from the AC outlet. Disconnect the interface cable from the printer.
2. Open the rear cover by unscrewing the two screws that secure the access cover and remove the cover.
3. When handling your SIMM modules, pay close attention to static electricity discharges, so be careful and hold the SIMM by the sides.
4. Install the SIMM into the slot at an angle, and then push it gently toward vertical alignment, it should click when it goes into place. DONT FORCE IT IN, be careful
5. Re-install the access cover and secure it with the screws.
6. Close the rear cover
7. Reconnect the interface cable, power cable and turn on the printer.
If all goes well, that should do it.
May 22, 2009 | Brother HL 1440 Laser Printer
HL-1440 Prints blank
Since you've already done the initial steps in troubleshooting the unit, another user serviceable solution it to replace the drum unit. Please note however that the drum unit is a expensive consumable part. It is best if you can test your unit using a known working drum unit. Beyond replacing the drum unit, the only option remaining is to have it professionally serviced. Blank print outs are classic symptoms of a main PCB failure, Laser unit failure and/or a loose wire harness. Please note that high voltage and current reside inside the printer. Please leave this tinkering to the professionals.
Jan 03, 2008 | Brother HL 1440 Laser Printer
Connecting printer to Windows Vista Laptop
I have a new HP laptop with Vista Home OS, and I just installed my HL-1440 with a driver that was installed automatically in the "New Printer" procedure in Windows, and it works perfectly.
--Gabriel
Nov 25, 2007 | Brother HL 1440 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
258 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
