Question about Whirlpool Duet GHW9150P Front Load Washer
No power getting to the front controls
No power on controls
  • Roger Miller May 11, 2010
    what code if any are you getting?
Where is the fuse box
Posted on Feb 01, 2010
  • 129 Answers
BOARD SHORTED OUT
Posted on Jan 31, 2010
How to connect my Bose 901 series vI speaker to yamaha rx v740 and rotel rb 1582. Appreciate your help. Thanks
The Bose controller gets wired in series between the pre-amp and the power amp.
I presume you plan to use the 901's as the front L&R pair. So the cables going from the 740's Pre-Out Front L&R go to the inputs on the Bose controller. The outputs of the Bose controller go to the power amp Front L&R channel inputs.
Aug 17, 2014 | Audio Players & Recorders
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
Power windows and locks do not work
The power windows are protected by 50A fuse 12 in the power distribution center. The orange/white wires from the PDC go to the driver door module and the pasenger door module. The driver door module controls the front power window motor directly and applies power to the driver rear power window switch to allow passenger control of the rear power window. Similarly, The passenger door module controls the front power window motor directly and applies power to the passenger rear power window switch to allow passenger control of the rear power window. BUT, operations can be computer controlled as part of the access control/theft deterrent system.
The power door locks also are protected by 50A fuse 12 in the power distribution center. The orange/white wires from the PDC also go to the driver door module and the pasenger door module. The driver door module controls the driver door lock motor/ajar switch. The passenger door module controls the passenger front door lock motor/ajar switch and supplies power for rear seat passenger control of the left and right rear door lock motor/ajar switches.
In short, if power from the fuse is getting to the door modules all windows and doors should work. If not, there may be a defect in the modules, the separate control switches, or even in the motors.
Sep 09, 2012 | Jeep 2004 Grand Cherokee LAREDO 4WD
06 srx sunroof doesnt work
Sorry Bill but you don't the tool's or knowledge to take on this job . Control module's involved.
Which one does your vehicle have ?
Power Sunroof System Components -- CF5
The power sunroof system consists of the following components:
• Front glass control module and motor assembly
• Front sunshade control module and motor assembly
• Sunroof switch
• Front glass panel
• Front sunshade
• Power supply for the front glass control module and motor assembly logic: RAP relay
• Power supply for the power sunroof system: SUNROOF MOD fuse 40 A
Power Sunroof System Components -- C3B
• Sunroof switch
• Front glass panel
• Front sunshade
• Rear sunshade control module and motor assembly
• Rear sunshade switch
• Rear sunshade
• Rear fixed glass panel
Aug 30, 2017 | 2006 Cadillac SRX
Trying to remove door latch on 1995 thunderbird. Car has power locks.
inside or outside latch? please rate
Section 01-14A: Handles, Locks, Latches and Mechanisms 1995 Thunderbird, Cougar Workshop Manual
REMOVAL AND INSTALLATION Latch, Door Removal and Installation
  1. Remove front door trim panel (23942) and watershield from front door (20124). Refer to Section 01-05 .
  1. Mark the location of the bolt retaining front door glass run front retainer (21572). Remove the bolt.
  1. Check all rod connections against the appropriate illustration. Correct any disconnected or loose connections and check operation before replacing parts.
  1. Remove power door lock actuator (218A42).
  1. Disconnect the rods from the front door latch (21812) . The front door latch remote control link (21940) and the latch-to-lock cylinder rod cannot be removed because of the rod's end configuration. Remove wiring from clip on front door latch shield.
  1. Remove front door latch control cylinder rod (22134) from the door lock cylinder (21985).
  1. Remove front door latch remote control and link (21818).
  1. Remove the front door latch retaining screws. Disconnect the door open warning lamp switch (14018) , if so equipped. Remove the front door latch from the front door .
  1. NOTE: Do not damage anti-theft shield.
    Remove anti-theft shield from the front door latch .
  1. Remove front door latch remote control link , front door latch control cylinder rods , and door open warning lamp switches from front door latch , where applicable.
  1. To install, reverse Removal procedure. Tighten front door latch retaining screws 4-8 Nm (36-70 lb-in).
Item Part Number Description 1 21852 Front Door Latch Push Button Rod 2 21940 Front Door Latch Remote Control Link 3 386656-S Bushing 4 21978 Door Latch Shield 5 218A42 Power Door Lock Actuator 6 22134 Front Door Latch Control Cylinder Rod 7 21812 Front Door Latch
Remote Control Assembly Door Latch
  1. Remove front door trim panel (23942) and watershield. Refer to Section 01-05 .
  1. Remove screw and washer assembly retaining front door latch remote control and link (21818) to front door (20124) .
  1. Rotate front door latch remote control and link to remove from front door latch remote control link (21940) .
Sep 27, 2009 | 1995 Ford Thunderbird
No lights or power comes on, door lock.repair man said control box so bought new one still no power,got 120 volt going in to box, (ghw9250ml0 = front load)
i think you brought the wrong board ,,i looked this up a night ago,,you need the power control board,,,im going to get the part number,,and you match it to the box or invoice,,,
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front loader he2t power button stuck
First of all, the power button is not a separate part. It's integrated into that whole interface and cannot be fiddled with. You need to take off top to get to console; you should see what else you need to take off to get the console off. There are some screws as well as plastic catches formed into the console that need to be depressed to disengage it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Kenmore 43142 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
