My 4yr old Esate Washer will not agitate and screams
My 4yr old Esate Washer was working fine med load then it stoped and wiill ony scream
  • 714 Answers
Motor coupling, clutch,transmission
Posted on Jan 31, 2010
Our IWL12 is making a screaming sound when filling
May just be the sound of the water running thru valve. try adjusting the tap and see if it changes the noise
Jun 29, 2009 | Fisher and Paykel IWL12 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
GE washer not agitating
when you pulled up agitator was the splined shaft moving back and forth ? If so replace the insert in the agitator. If not the problem is in the transmission .
Dec 11, 2008 | Washing Machines
Agitator
hi thanks for the question . i think the problem is with themotor coupling that is on the motor and transmission you have to remove the cabinet 2 screws on the console . remove .lift console . remove 2 brass clips on top disconnect lid switch pull cabinet towards you. remove the water pump 2 spring clips . remove the clips on the motor disconnect the power to the motor remove the motor . replace drive coupling thanks the appliance doc
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont agitate with med - large loads
Without knowing the age of your machine, your agitator "dogs" may be wearing or worn out. It should be fairly easy to check them out. You will need to figure out how to remove the agitator Usually the agitator will have a fabric softener dispenser or a cap on the top. Pull the dispenser/cap off the top of the agitator and you may see a screw holding the agitator in place. Once you lift the agitator out, the "dogs" should be visible. Most appliance stores should carry the dogs for your particular washing machine. I've added a couple of photos so you have an idea what to look for.
Black powder under the motor??? The motor uses carbon "brushes" to electrically make the motor move. Without going into motor theory, I would tell you that the black powder, in a small amount, is normal. The brushes can be replaced, and again, can be found at most major appliance dealers
Jan 11, 2008 | Amana ALW880WH Top Load Washer
Very loud squealing noise in spinn.
If your Maytag is a top loader equipped with a vertical transmission under the tub, the squealing may be coming from, either the brake assembly, or the snubber which the entire pedestal rides on.  Could you please post back comments and let me know if this is the type of washer you have?
Oct 18, 2007 | Maytag Performa PAV2200
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
