Question about Philips 42PFL3704D LCD TV
My new hdtv makes a loud buzzing sound. it is connected to directv.I used a video connection because when the hdmi is used the sound is lost when the power is turned off and then back on. The tv is a philips 42" and replaces an old tv which also has the buzzing when connected to directv. Could it be the box? It is a new hd box and was professionally installed on the old tv. The place where I signed up for directv will not send the installer back to fix it. When I called directv they said it is not the box.
    Problem Solver:
  • 9 Answers
I have comcast and get buzzing from the box when everything is off. Do you have the option of unplugging it and having the t.v. on by itself or will the provider have to come reprogram it. If not, disconnect box to rule out t.v. before t.v. warranty is out.
Posted on Jan 31, 2010
It has a loud buzzing noise how do I fix that problem?
It appears that your connections are not correct. Please switch off the TV. Disconnect all the cable. Wait for some time. Reconnect cables one by making sure you strictly follow the color code i.e. that red pin cable must go in the red socket. After all the cables are connected switch on the TV. Loud buzzing noise is due to wrong connection of cables especially the Earthing/Neutral
Apr 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Is this TV HD capable?
This is not an HDTV. However, that does not mean you cannot use it to view the HD channels with DirecTV, you just wont be able to view them in hi-def. Use the component inputs from the directv tuner and plug those into the proper component inputs of your JVC. Once you see the DirecTV picture on the screen, go into menu... setup (with the directTV remote) and make sure that the only resolution checked is 480i. DirecTV with 'downconvert' those cannels to standard def, and they will still look pretty good though the component connection...
... now, in answer to your next question: "What exactly do I need to view HDTV with DirecTV?"...
1. A television that will accept 720p or 1080i signals.
2. A DirecTV HD Tuner.
3. Any DirecTV service BUT you must purchase the HD pack so that they will 'unlock' the HD channels
4. The proper cables to hook in between your DirecTV HD receiver and your HD-capable TV/Monitor. You may use either HDMI or component video cables, so long as your TV will accept them. Tune your TV input accordingly. When using component video cables, you must also run a separate cable(s) for audio...
Take care,
Rob
ps. DirecTV HD tuners do not have an RF 'out'. ("coaxial or ch3/4 connection")
Mar 05, 2009 | JVC AV-32D502 32" TV
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection of HDMI and Directv box
Monlink is the Connection I used with my Directv. All you need to use is the HDMI cords. Are you trying to also connect to stereo system or something other than a straight HDMI connection from Directv Box to WD-62525
Feb 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My TV makes a loud buzzing noise whenever there is a bright picture on
This is usually caused by video signals overdriving circuits. Too much video causes what you are describing. This is sometimes caused by a bad cable or connection, either a TV cable or a video cable. Hopefully it's not a projector problem. If you can check the connections from your receivers and VCR with the projector on you might be able to pin point the problem. Be gentle and if there is adoubt about a cable, just replace it.
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Samsung lcd ln46a550pf3 no sound from hdtv reciever
ok your tv does not come with the very best sound, you have to get a receiver 7.1 or you can use the optical wire , that's if the system you are using has that option.
Apr 10, 2008 | Samsung LN-T4665F 46 in. LCD Television
Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Loud buzzing
check your connections again, if you have the audio and video reversed you will get this exact problem no video/ fuzzy video, and squealy noise out of only one speaker (other will likely sound correct) You're watching the sound channel, and listening to the video channel basically... hehe
Aug 14, 2007 | Zenith P42W46X 42 in. Plasma EDTV
Philips 42PFL3704D LCD TV Logo
364 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
