Wont pump out water
I have a Whirlpool top loader 6ALSQ8000 and it wont pump the water out of the machine i have taken it apart and am not sure which motor needs replacing if that is what it is. i look what seems to be the main motor oput part No 3363190 does this entirely need to be replaced or just part of it
  • 49 Answers
First of all does it wash? if it does the motor does not need replacing. the drain pump is located on the front of the motor and has a clip at the top and one at the bottom. it has 2 hoses attatched to it. remove the pump and check if anything is caught inside it. if not the pump will need replacing. let me know how you go
Posted on Feb 18, 2008
Whirlpool top loader about 4 months old wont rinse/spin clothes have detergent stains Im am using correct HE detergent and amount. Disgusted.
does the water pump out ok? could just be a blocked pump. alternatively are you in an area with hard water?
Nov 11, 2013 | Whirlpool Washing Machines
Whirlpool washing machine LA5310XPWO wont agitate -- what would cause this and how can it be repaired?
Is this a top or front loader? If it is a top loader do you hear the motor run? If you do the first thing to check is the rubber driver between the motor and the transmission. One way to chek if the motor runs is to fill it with water and put it into spin. If it pumps the water out that means the motor runs. If the rubber driver is broke (happens often) it will neither wash nor spin.
May 20, 2011 | Whirlpool Washing Machines
How do I take my kenmore washer apart..... I have water leaking at the bottom of my washer. Thanks
Good day,
If it is a top loader then the most common problem is a leaking pump, which is easy to change.
The link below is not for leaks but shows you the details on taking it apart. Kenmore machines are a product of Whirlpool.
http://www.youtube.com/watch?v=WLPGs2UMUJc&NR=1
Oct 05, 2010 | Kenmore Washing Machines
Water will not drain machine runs on wash cycle
If this is a top loader you have a bad lid switch.
If this is a front loader I suspect something is in the pump filter.
I took the time to write a tip about both and am going to include both:
Top loader woes
Front Loader woes
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 30, 2010 | Whirlpool Washing Machines
The washer smells bad. We have taken it apart and cleaned between the tubs. The agitator turns in both directions
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 21, 2010 | Whirlpool LSQ9659PW 2 SPD 10 CYC 4 TEMP 5...
My Whirlpool Gold leaking water
the water pump is bad, call a repairman usually only 75 to 85 bucks depending on where you live
Mar 01, 2010 | Whirlpool Washing Machines
Top loader ult II wont drain, only agitates -and front leak slow
If the motor is running but no water from the drain hose then yes the pump may be bad or there could be something like a sock stuck in it.
Go here for: http://www.repairclinic.com/Whirlpool-Washing-Machine-Parts
appliance parts, help & more
May 05, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore 42042 front loader
Buy affresh wsher tablets from whirlpool corp. They keep the wsher from smelling and they clean the washer too. They say they are for front loaders but they work great on top loader too!!!!!!!
Nov 10, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
122 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
